Plasmastream Heating of a Sample in CFX
Old   May 21, 2015, 10:58
Post Plasmastream Heating of a Sample in CFX
ChristianGermany is on a distinguished road
Hello guys and girls,
I have a problem to which I tried some stuff with Ansys Fluent, but I donīt get it or maybe I have taken the wrong route to it.
This is the problem I am trying to solve in ANSYS Fluent. I have a plasmastream source with a diameter of about 20 mm, at 1 bar and a temperature of 2500 K which streams at a sample holder with about 0,5 kg/s. (For simulation purposes I could assume that it is just air with 2500K) This hits a round cylindrical Sample Holder which consists of a ceramic (0.1 W/mē thermal conductivity) and a sample (10 W/mē) inside the ceramic middle part so that it "sees" the stream. I propably have convection outside of the ceramic, since the stream flows around the sample and heat is radiated from the ceramic and the sample to the outside air at 300K.
If possible, could someone maybe give me some advice on how I could simulate that problem in Fluent or CFX ? Thank you very much !
Best Regards
Christian
ChristianGermany is offline   Reply With Quote
Old   May 21, 2015, 18:46
The air only version of this simulation is straight forward - a CHT simulation with a compressible gas flow. As the plasma in this case does not appear to have much in the way of electric field effects and appears to be just a fast flow you may be able to use some modified EOS to account for some plasma effects - not sure on that, you would have to investigate.
But CFX and Fluent can do this sort of simulation. Do the tutorials which are provided with the software to get a feel for how the basics are done and go from there.
convection, heating with stream, sample holder
ATTENTION! Reliability problems in CFX 5.7 Joseph CFX 14 April 20, 2010 15:45
CFX pressure in Simulations problem nasdak CFX 1 April 14, 2010 13:22
heat conducting in a solid domain Rogerio Fernandes Brito FLUENT 0 March 18, 2008 17:25
CAE program for heat conducting Rogerio Fernandes Brito FLUENT 0 February 3, 2008 11:22
CFX 4.4 installation problem Pandu Sattvika CFX 1 December 1, 2001 04:07
