May 14, 2015, 01:34 |
RIP boiling
Rep Power: 12 |
hi all,
actually i doing simulation of jet impingement on heated plate with heat flux of 70E+04 using RPI boiling model.i use Auto time scale with time scale factor of 1. other parameter i set are: Bubble diameter =0.000012 [m] saturation temperature= 373.15 [k] subcool liq temp =77[k] Inlet temp =296.15 [k] saturation temperature is not achieved and showing the error: Parallel run: Received message from slave ----------------------------------------- Slave partition : 4 Slave routine : ErrAction Master location : RCVBUF,MSGTAG=1012 Message label : 001100279 Message follows below - : +--------------------------------------------------------------------+ | ERROR #001100279 has occurred in subroutine ErrAction. | | Message: | | Stopped in routine cal_TSUP1 | | | | | | | | | | | +--------------------------------------------------------------------+ +--------------------------------------------------------------------+ | An error has occurred in cfx5solve: | | | | The ANSYS CFX solver exited with return code 1. No results file | | has been created. | +--------------------------------------------------------------------+ End of solution stage. +--------------------------------------------------------------------+ | Warning! | | | | After waiting for 60 seconds, 1 solver manager process(es) appear | | not to have noticed that this run has ended. You may get errors | | removing some files if they are still open in the solver manager. | +----------------------------------------------- if anyone have idea about please suggest me |
May 14, 2015, 05:20 |
Mr CFD
Post a picture of your setup.
What is the speed of your jet? Why do you expect boiling to occur? |
May 19, 2015, 01:59 |
Rep Power: 12 |
Dear RicochetJ,
Many thanks for response, i refer a tutorial related to RPI boiling. As i apply tutorial condition to my case its going to right, but as i change the condition the temperature of liquid increases beyond the saturation temperature. The condition are as follows: Tutorial condition: Ref. pressure = 4.5 Mpa (sat temp = 530.65 K) sub cooling= 58.2K our condition: Ref pressure= 0.1 Mpa (sat temp =373.15 K) subcooling = 3.15K and i change other properties like Density, viscosity, thermal conductivity, specific heat according to ref pressure for both vapor and liquid in Material. |
May 19, 2015, 02:06 |
Mr CFD
What is your onset temperature for nucleate boiling and is this onset temperature achieved in a single phase simulation without the RPI boiling model enabled?
May 20, 2015, 06:46 |
Rep Power: 12 |
Dear sir,
first i try replace tutorial conditions (4.5 Mpa) by our condition (0.1 M pa) one by one and check for every change and its going right. but as i change the vapor density and specific heat capacity in material corresponding to 0.1 Mpa, program is not working. Is this RPI boiling is working for high pressure ? |
May 21, 2015, 16:27 |
Mr CFD
Yes the RPI boiling model has been developed and validated against high pressure cases (think nuclear reactors for example). You can get it to work for low pressure cases but you need to know stuff like the nucleation site density, bubble detatchment frequency, onset of nucleate boiling etc.
It's not easy. Read up on papers by the Helmholtz Centre in Dresden. They're behind alot of these kinds of models. They have some papers on sub cooled boiling which relates to low pressure boiling. |
May 22, 2015, 01:56 |
Rep Power: 12 |
Thank you so much Ricochet. i will try it
VOF Boiling | rawe666 | STAR-CCM+ | 8 | March 14, 2018 23:55 |
Flim Boiling Boiling | tsram90 | FLUENT | 3 | October 24, 2016 09:12 |
Evaporating & Boiling Point | ilphma | FLUENT | 0 | July 12, 2014 04:57 |
how to model boiling process | wanghong | FLUENT | 2 | October 1, 2010 17:07 |
