Home > Forums > CFX
Problem in using cfx in Linux with supercomputer
Old   May 20, 2015, 03:27
Default Problem in using cfx in Linux with supercomputer
Chen Di
Melvins is on a distinguished road
Now I have made a .def file in Windows cfx, and put it into the supercompter.
I was told to use terminal to submit a script flie to run the .def file.
Then there comes the error, it said 'cfx5solve: command not found'.
Here is the script file:
#PBS -N test
#PBS -l nodes=1pn=8
#PBS -j oe
#PBS -l walltime=200:00:00
#PBS -q blade
cd $PBS_O_WORKDIR
echo my job id is $PBS_JOBID | tee test.log
echo run nodes is following: | tee -a test.log
cat $PBS_NODEFILE | tee -a test.log
echo pwd is `pwd` | tee -a test.log
echo begin time is `date` | tee -a test.log
id=`echo $PBS_JOBID|awk -F. '{print $1}' `
NP=`cat $PBS_NODEFILE|wc -l`
cd /public/home/dichen/CFX
cfx5solve -def hawkmoth 60deg mesh2.def -par-local -partition 8
echo end time is `date` | tee -a test.log
I'm an idiot in Linux, please help, my dear friends!
Melvins is offline   Reply With Quote
Old   May 20, 2015, 03:42
Lance
Lance is on a distinguished road
My guess is that you dont have the path to CFX in your $PATH.
Try to specify the entire directory to cfx5solve, i.e. change
to
/software/ansys/16.0/v160/CFX/bin/cfx5solve -def mesh2.def
(change the bold stuff to where you have your installation.)
Im not sure what you mean with "hawkmoth 60deg", it shouldnt be directly after -def. Also, you might want to specify -start-method "Intel MPI Local Parallel" or whatever MPI you want to use.
Lance is offline   Reply With Quote
Old   May 20, 2015, 04:52
Chen Di
to
Thank you for your quick reply,
"hawkmoth 60deg" is the def file name, so you mean I should write this line like '/software/ansys/16.0/v160/CFX/bin/cfx5solve -def hawkmoth 60deg mesh2.def -par-local -partition 8 -start-method -Intel MPI Local Parallel' ?
Best,
Old   May 20, 2015, 05:03
Lance
Avoid spaces in the file name. Use under_score instead.
/software/ansys/16.0/v160/CFX/bin/cfx5solve -def hawkmoth_60deg_mesh2.def -par-local -partition 8 -start-method "Intel MPI Local Parallel"
Thread Tools
Trackbacks are On
CFX problem in ubuntu (linux) Vigneshramaero CFX 0 July 13, 2012 10:22
[ICEM] issue occur after extrude 2D airfoil mesh and convergence problem in CFX shiyun ANSYS Meshing & Geometry 4 May 9, 2012 19:55
cfx mesh problem... mactech001 ANSYS Meshing & Geometry 0 November 5, 2009 03:19
Workbench (CFX) bucket problem njsavage ANSYS 0 April 29, 2009 17:10
Moving Mesh Run problem - Scientific Linux G. SE CD-adapco 2 May 7, 2008 07:15
