Edit/stop run in progress without solver manager
Old   October 22, 2007, 08:48
Default Edit/stop run in progress without solver manager
N.R.
I have a couple of questions concerning transient runs:
1) I have a transient run in progress, but cannot log on to the machine. But I can see via a shared drive, that the solver still produces output files (.trn).Is there a way to place a file with a stop coommand in the run directory (similar to CFD-ACE)?
2) Are there other ways (commandline) to stop the run?
3)In case I have to force reboot. How can I restart a transient run? Will thsi work after a forcing the solver to quit?
4)Is it possible to load only the first say 300 transiemnt steps, even if no results file exists?
Thanks in advance,
N.R.
Old   October 22, 2007, 09:03
Default Re: Edit/stop run in progress without solver manag
opaque
Dear N.R.
cfx5stop -directory full_path_to_my_run_001.dir
Opaque
Old   October 22, 2007, 09:08
N.R.
Thanks opaque!
What if I have no commandline access and can only create files in the run-directory? (question 1) Is there a way?
What about this question?
Thanks,
N.R.
Old   October 22, 2007, 09:15
Anantha
You can create a stp file inside the .dir folder of the run. The simulation will stop naturally. But if your run is a parellel one using more than one processors, I don't think it will exit naturally (some errors are expected and the run may end up with out writing result file).
Regards Anantha
Old   October 22, 2007, 09:51
longbow
Placing a "stp" file in ".dir" folder should stop a parallel run normally too. By the way, that "stp" file should be a blank file without any content.
Old   October 22, 2007, 10:15
Anantha
I have faced problem few times when I tried to stope the solver in that way. It says some kind of communication error between the processors (I do not remember the esact error message now) and quits with out writing the result file. I am not sure what exactly is the error.
Old   October 24, 2007, 12:43
HekLer
Putting an stp file there is no different than writing the final results.
If it fails then this is a bug. Report it to support.
Old   June 16, 2015, 01:18
Post
kar.coep is on a distinguished road
I am as well trying to stop a parallel run. What kind of 'stp' file do I need to create? would it be named just 'stp' like mon file or 'stp.stp'?
kar.coep is offline   Reply With Quote
Old   June 16, 2015, 03:48
Matthias Voß
mvoss is on a distinguished road
Just stp ... no content, no file format. On a Linux like OS think of a "touch stp" command.
mvoss is offline   Reply With Quote
Old   June 16, 2015, 10:16
Post
I did create a stp file in .dir folder while the run was going on.
But it did not stop the run.
any other ideas?
Old   June 16, 2015, 19:07
Opaque's post #2 describes the recommended way of stopping a run from the command line.
Old   June 17, 2015, 01:53
Post
  #12
After entering CFX5stop command, it says 'The Process will stop shortly'
But it continues till the maxiterations
Old   June 17, 2015, 02:13
You need to either put the CFX executables in your path, or run it from a command line started from the CFX launcher as this automatically puts the correct path in.
thobois class engineTopoChangerMesh error Peter_600 OpenFOAM 4 August 2, 2014 09:52
CFX Solver Manager famarcfd CFX 5 June 17, 2012 19:33
How can i run a steady-state problem using dsmcFoam solver? spk OpenFOAM 2 October 19, 2011 05:33
Help-Edit Run in Progress BalanceChen CFX 0 March 30, 2011 09:23
CFX 5.5 Roued CFX 1 October 2, 2001 16:49
