CFX - fatal error
Old   June 18, 2015, 07:55
Default CFX - fatal error
shashank
hanniballecter is on a distinguished road
I am modelling an ejector. It has a nozzle inlet for water and another inlet for air perpendicular to water inlet and above the nozzle outlet.
I am using CFX multiphase option. For inlet velocities of water 2ms-1, 4 ms-1, 6ms-1, the solution worked fine. It did not converge but it did give a stable solution after 7000 iterations.
Now for inlet velocity 21ms-1 , i am getting the error - Fatal error in linear solver.
Boundary conditions were , inlet-water : inlet
inlet-air : opening
outlet : outlet ( the solver suggests to put it as opening but for opening condition it asks for volume fraction for phases which we do not know)
the solution gives error after some 500 iterations.
Any idea how i can rectify this error ?
hanniballecter is offline   Reply With Quote
Old   June 18, 2015, 07:56
shashank
A wall has been placed at portion(s) of an INLET |
| boundary condition (at 100.0% of the faces, 100.0% of the area) |
| to prevent fluid from flowing out of the domain. |
| The boundary condition name is: inletair. |
| The fluid name is: water. |
| If this situation persists, consider switching |
| to an Opening type boundary condition instead. |
| ****** Notice ****** |
| The fluid name is: air. |
Old   June 18, 2015, 18:46
These FAQs are relevant:
http://www.cfd-online.com/Wiki/Ansys...do_about_it.3F
http://www.cfd-online.com/Wiki/Ansys...f_an_OUTLET.22
The backflow at the inlet may well be caused by the convergence problem. Check the result in CFD-Post to see whether it is likely to be real or not. If it is real then you will need to adjust your simulation to handle it.
Old   June 19, 2015, 02:55
shashank
oh.. okay. Thank you.
Problem running perturbUCyl sen.1986 OpenFOAM 17 June 4, 2019 05:56
CGNS lib and Fortran compiler manaliac Main CFD Forum 2 November 29, 2010 06:25
[swak4Foam] groovyBC: problems compiling: "flex: not found" and "undefined reference to ..." sega OpenFOAM Community Contributions 12 February 17, 2010 09:30
Installation OF1.5-dev ttdtud OpenFOAM Installation 46 May 5, 2009 02:32
Compiling problems with hello worldC fw407 OpenFOAM Installation 21 January 6, 2008 17:38
