May 25, 2015, 07:11 |
heat transfer screws
Marcin
Rep Power: 12 |
Hello
I have to model a heat transfer on the steel screws. How to simplify and model this problem. The black cube is filled with screws. Green cube is a fluid domain. On the top and the bottom wall I have temperature 700 C. Initialization Fluid domain 20 C screws 20 C. Transient analysis - 9 hours. How to model black domain ?? Porosity, multiphase, particle tracking ?? Best regards from poland |
May 25, 2015, 09:05 |
Mr CFD
Rep Power: 14 |
Model the thousands of screws as a porous medium.
May 26, 2015, 02:09 |
Marcin
Rep Power: 12 |
Thanks
And how to determine interfacial loss coefficient ?? |
May 26, 2015, 02:11 |
Marcin
Rep Power: 12 |
sorry
interfacial area density ?? |
May 26, 2015, 07:25 |
Mr CFD
Rep Power: 14 |
Why do you need the interfacial area density? This is a single phase simulation isn't it?
Regarding loss coefficients: they can be found in text books to start with. |
May 29, 2015, 01:12 |
Marcin
Rep Power: 12 |
thanks for Your answer
I define porous domain. Everything is good when I define heat transfer between fluid domain and porous. But when i define velocity from left wall to right wall (fluid domain) imbalances go high and after couple time steps i get error overflow. What I do wrong?? Best regards |
May 29, 2015, 10:09 |
Edmund Singer P.E.
Rep Power: 20 |
Did you try increasing your Source Coefficient?
Is it large to begin with? |
May 30, 2015, 02:26 |
Marcin
Rep Power: 12 |
Hello
What do You mean ?? I have another questions below interface area density is heat transfer coefficient can i take value form previous simuation with one screw which I determine to 2 W/m2K?? And what about heat transfer on solid? Can Ileave adiabatic ?? Best regards |
May 30, 2015, 02:30 |
#9 |
Marcin
Rep Power: 12 |
so when air with defined velocity going into porous domain all imbalances goes high and after couple timesteps I get error overflow
Anyone knew any tutorials with immersed porous medium like in my case ?? |
June 1, 2015, 02:08 |
#10 |
Marcin
Rep Power: 12 |
Can anyone help me ??
June 2, 2015, 08:32 |
#11 |
Edmund Singer P.E.
Rep Power: 20 |
Look up Source Coefficient in CFX help. I briefly looked over your post and it seems like this could help you.
Take a look, and ask more questions after. If you need more help, describe your problem more, and perhaps post some pics of your setup and settings. |
July 22, 2015, 05:48 |
#12 |
Marcin
Rep Power: 12 |
thanks a lot of your answers
Quick Tips and Tricks, Tutorials FLuent/ CFX (CFD) https://howtooansys.blogspot.com/ |
July 23, 2015, 08:37 |
#13 |
Marcin
Rep Power: 12 |
can anyone tutorials for porous medium with heat transfer but immersed (all walls) on the fluid domain ??
Error finding variable "THERMX" | sunilpatil | CFX | 8 | April 26, 2013 07:00 |
Question about heat transfer simulation | Anna Tian | Main CFD Forum | 0 | January 25, 2013 18:53 |
Modelling the heat transfer during compression and cooling of natural gas | pano | Main CFD Forum | 0 | December 10, 2010 15:53 |
Heat Transfer in Porous Medium | eryan | STAR-CD | 0 | September 28, 2010 13:14 |
Convective Heat Transfer - Heat Exchanger | Mark | CFX | 6 | November 15, 2004 15:55 |
