Error ‘The path is not of a legal form.’ in Workbench running CFX
1 Attachment(s)
I use Ansys 16.0 workbench to run CFX simulations by ‘Table of Design Points’ in ‘Parameter Set’. Here is the problem The ‘Update’ button could run the ‘DP0(Current)’ simulation normally(successfully). But when I use ‘Update All Design Points’ button, I got error information ‘Update of the Solution component in XXX for design point # failed: The path is not of a legal form.’ I think the problem shall be from the ‘Solver Input File’ path setting in ‘Run Definition’ as whether I setup an initial value or not, the error remains. The setup I did is shown in the figure attached. I tried different ‘Solver Input File’ paths, e.g. ‘…./dp0/CFX/CFX/XXX.def’ but none of them works. It seems the original default setting, which is a path to a non-relevant folder and not existing file that makes no sense, could work all things well. But how to recover to the default setting? May I ask why I got this error message and how to solve this problem? |
