Error ‘The path is not of a legal form.’ in Workbench running CFX
Old   June 29, 2015, 04:16
Question Error ‘The path is not of a legal form.’ in Workbench running CFX
Anna Tian's Avatar
Meimei Wang
Anna Tian is on a distinguished road
I use Ansys 16.0 workbench to run CFX simulations by ‘Table of Design Points’ in ‘Parameter Set’.
Here is the problem
The ‘Update’ button could run the ‘DP0(Current)’ simulation normally(successfully). But when I use ‘Update All Design Points’ button, I got error information ‘Update of the Solution component in XXX for design point # failed: The path is not of a legal form.’
I think the problem shall be from the ‘Solver Input File’ path setting in ‘Run Definition’ as whether I setup an initial value or not, the error remains. The setup I did is shown in the figure attached. I tried different ‘Solver Input File’ paths, e.g. ‘…./dp0/CFX/CFX/XXX.def’ but none of them works.
It seems the original default setting, which is a path to a non-relevant folder and not existing file that makes no sense, could work all things well. But how to recover to the default setting?
May I ask why I got this error message and how to solve this problem?
Best regards,
Meimei
Anna Tian is offline   Reply With Quote
Old   July 1, 2015, 05:18
Question
Anna Tian's Avatar
Meimei Wang
Originally Posted by Anna Tian View Post
Here is the problem
Could anyone help on this question?
Best regards,
Meimei
Question about Workbench CFX error message Anna Tian CFX 6 June 21, 2014 12:13
Adding new fluid material in workbench and using it in cfx nirajpandya ANSYS 1 May 7, 2014 05:35
RSH problem for parallel running in CFX Nicola CFX 5 June 18, 2012 18:31
mesh from Workbench Simulation to Cfx Pre? Dai CFX 6 November 11, 2006 12:19
Running CFX on a cluster jvk CFX 9 September 19, 2002 22:22
