Meimei Wang
Rep Power: 14 ![]() |
I run CFX simulation by workbench. After I start to run the simulation, the simulation stuck at the message:
‘The MeTiS partitioning method allocates additional memory. Total memory usage will therefore exceed the values shown above.’ Then the simulation doesn’t proceed anymore. I’m quite sure that I shall have enough memory (128 GB) available for that simulation (16 millions structured grids from ICEM, steady state SST). The bad thing is: it doesn't give any error information. So that I have no clue what causes the problem and how to solve it. I’m wondering what’s the reason of it? And how to solve this problem? Any hint?
Best regards, Meimei |
Jinwhan Ryuk
Rep Power: 11 ![]() |
Do you have enough parallel licenses? Have you try to change memory allocation factor? 1.2x or 1.5x in solver option? Do you solve multiphase or multicomponent problem?
#3 | |
Meimei Wang
I haven't tried memory allocation factor, because i never got a hint that tells memory is not enough.
#4 | |
Meimei Wang
Just tried memory allocation factor of 0.8 and 1.5. Not working
Jinwhan Ryuk
Do you have many interger interfaces? What is the differences between the two problems?
#6 | |
Meimei Wang
So I did the tests as below. I run only domain1, no that problem. I run only domain2, no that problem. I create a simple domain3. Connect domain1 and domain3 by GGI. Working.
#7 | |
Meimei Wang
http://www.cfd-online.com/Forums/cfx...rted-icem.html
#8 | |
Meimei Wang
Never got this 'slow' problem before at the same workstation. So it shall not be caused by hardware.
#9 |
Rep Power: 136 ![]() ![]() ![]() ![]() |
Very complex configurations can take ages to start. For instance lots of GGIs or boundaries, lots of CEL, lots of additional variables.
#10 |
Meimei Wang
Is there a good way to reduce the too long starting time besides reducing these factors you mentioned?
#11 |
ANSYS has already worked hard to make simulations start as quickly as possible. There are no quick fixes to make it go faster, if there were they would already be in the software.
There must be something about your simulation which is causing the very long start time. If you want us to help you you will have to describe what you are doing. For instance: How many nodes in your mesh? How many boundaries, GGIs and anything else you have set up? |
#12 | |
Meimei Wang
#13 |
17 million grids (elements?) is getting large, but should not take 5 hours to start unless you have run out of memory or some other problem.
I would do some basic fault finding. Take a simple simulation (like a tutorial example) and make it 17 million elements. Does it run quickly? Remesh your simulation with half the number of elements - does it start quickly? |
#14 | |
Meimei Wang
By the way, once I have run the simulation and use its result file as initial solution of a new simulation. The simulation would start very fast without any problem. So I guess maybe that's because the initial solution grids of the 'too slow' simulation do not correspond to the new simulation. I asked the question below as well for this reason. http://www.cfd-online.com/Forums/cfx...nning-cfx.html
#15 | ||
#16 | |
Meimei Wang
#17 |
Do not specify an initial condition results file. Leave it blank.
#18 | |
Meimei Wang
But it actually uses one as I got the following lines in the output file. ‘ INITIAL VALUES SPECIFICATION: INITIAL VALUES CONTROL: Use Mesh From = Solver Input File Continue History From = Workbench Initial Values END INITIAL VALUES: Workbench Initial Values Option = Results File File Name = 20_fine_019.res END END END ‘ If I change the setting, i will get the error message as stated in the thread below. http://www.cfd-online.com/Forums/cfx...nning-cfx.html
#19 |
Edmund Singer P.E.
Rep Power: 19 ![]() |
Lets go back to your original warning. Did you increase the amount of memory for the "partitioner" (not the run, there is a difference)?
I dont use Solver Manager to start my jobs but in command line it is: -size-part <factor> I have had to increase this with 2 domain GGI runs before as CFXs estimate is low. The command -size will just increase the solver memory, but not alter the allocation for the partitioner. |
#20 | |
Meimei Wang
According to the discussions above, there's no hint that the problem is caused by lack of memory up to what we see now.
Display Modes | |
Waterbell Simulation | o.b.m | Fluent Multiphase | 1 | November 5, 2015 06:55 |
mass flow rate issue in supersonic nozzle simulation | xkang | FLUENT | 0 | July 31, 2014 17:06 |
Simulation of a complex wing in solidworks flow simulation | niels1900 | FloEFD, FloWorks & FloTHERM | 6 | April 20, 2011 11:44 |
GUI crash and simulation engine still running | RPJones | FLOW-3D | 2 | November 9, 2010 09:18 |
3-D Contaminant Dispersal Simulation | Apple L S Chan | Main CFD Forum | 1 | December 23, 1998 11:06 |
