Flow Direction: normal to boundary!!!
Old   June 26, 2007, 07:48
Default Flow Direction: normal to boundary!!!
Atit
My current simulation is the flow between circular flat plate(both plates lie parallel to X-Z plane). The continuous flow of air flows in radially from the perimeter towards the center of the plate where there is the outlet. I specified 'INLET' with zero total pressure, flow direction: normal to boundary condition, and static temp=308K at the inlet position of the domain.
After the computation, I found in CFX-Post that there is the Y-component of velocity at the inlet surface. This could not be possible, couldn't it? 'cause Y axis lie parallel to the inlet surface!!!
Then I change the flow direction at inlet position in CFX-Pre to that
FLOW DIRECTION:
Option = Cylindrical Components
Unit Vector Axial Component = 0
Unit Vector Theta Component = 0
Unit Vector r Component = 1
AXIS DEFINITION:
Option = Coordinate Axis
Rotation Axis = Coord 0.2 (this is Y axis)
However I still have the Y-component of velocity at the inlet surface.
Do anybody know what wrong with this? Does 'flow direction: normal to boundary' really mean that there must be no flow in parallel direction of the surface?
Thank you for your consideration.
Atit
Old   August 2, 2015, 14:42
turbomax is on a distinguished road
Hi Atit,
I know it's been eight years but did you ever manage to solve this problem? I am having a similar issue.
turbomax is offline   Reply With Quote
Disturbed flow field at outlet boundary (Multiphase flow through pipe) Michiel CFX 17 April 21, 2010 11:14
Flow boundary conditions Turbulent CFX 3 April 20, 2010 05:15
NACA0012 geometry/design software needed Franny Main CFD Forum 13 July 7, 2007 16:57
specifying the flow direction in periodic boundary joanna FLUENT 2 February 27, 2006 22:09
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues michele OpenFOAM Meshing & Mesh Conversion 2 July 15, 2005 05:15
