September 1, 2015, 16:13 |
defining a new material i.e Glass
Muhammad Umair
Rep Power: 10 |
hi everybody,,,,,
i have created a new solid material in cfx that will go under heat transfer from 100 degree C tp 920 degree C. but im confused in some of the properties of the materials. 1) how to set the reference temperature and reference specific enthalpy and reference specific entropy... i highlighted it in the snapshot of the printscreen that i have attached as pic 1 ,,, Second problem is in chosing the right material type that i have highlighted in attached pic 2. please guide me,,,,, |
September 1, 2015, 18:34 |
Rep Power: 143 |
If your temperature range is from 100C-920C then you can use 100C as a reference temperature. The simulation is rarely sensitive to this value so you can use what ever you like in it most of the time.
The other question is just defining what grouping it is in so it appears in the right menus. |
Defining new material as inert-particle | Julian K. | FLUENT | 3 | August 25, 2020 22:39 |
Compression stoke is giving higher pressure than calculated | nickjuana | CFX | 62 | May 19, 2015 13:32 |
CFX pre error in assigning material to the domains | madan | CFX | 1 | February 18, 2015 01:55 |
Simulation of granular material | Philippe | Main CFD Forum | 1 | February 13, 2013 08:10 |
Fluent is not accepting Modification in Material properties | er.mkumar | FLUENT | 0 | September 1, 2012 14:24 |
