Problem with the Remesh. ICEM-CFX
Hi. I have Problem with the Remesh, the interrupt condition. shooting and does not Remesh. Can you help me with that? thanks.
ICEM-CFX.CCL ------------------------------------------------------------------------------------------------------ FLOW: Flow Analysis 1 SOLUTION UNITS: Angle Units = [rad] Length Units = [m] Mass Units = [kg] Solid Angle Units = [sr] Temperature Units = [K] Time Units = [s] END ANALYSIS TYPE: Option = Transient EXTERNAL SOLVER COUPLING: Option = None END INITIAL TIME: Option = Automatic with Value Time = 0 [s] END TIME DURATION: Option = Total Time Total Time = 10 [s] END TIME STEPS: Option = Timesteps Timesteps = 0.01 [s] END END DOMAIN: Default Domain Coord Frame = Coord 0 Domain Type = Fluid Location = BODY BOUNDARY: Inlet Boundary Type = INLET Location = INLET BOUNDARY CONDITIONS: FLOW DIRECTION: Option = Normal to Boundary Condition END FLOW REGIME: Option = Subsonic END MASS AND MOMENTUM: Mass Flow Rate = 50 [kg s^-1] Option = Mass Flow Rate END MESH MOTION: Option = Stationary END TURBULENCE: Option = Medium Intensity and Eddy Viscosity Ratio END END END BOUNDARY: Oulet Boundary Type = OUTLET Location = OULET BOUNDARY CONDITIONS: FLOW REGIME: Option = Subsonic END MASS AND MOMENTUM: Option = Average Static Pressure Pressure Profile Blend = 0.05 Relative Pressure = 5 [psi] END MESH MOTION: Option = Stationary END PRESSURE AVERAGING: Option = Average Over Whole Outlet END END END BOUNDARY: Pared Boundary Type = WALL Location = WALL BOUNDARY CONDITIONS: MASS AND MOMENTUM: Option = Free Slip Wall END MESH MOTION: Option = Unspecified END END END BOUNDARY: Wall Boundary Type = WALL Location = BOX BOUNDARY CONDITIONS: MASS AND MOMENTUM: Option = No Slip Wall Wall Velocity Relative To = Mesh Motion END MESH MOTION: Option = Specified Displacement DISPLACEMENT: Displacement X Component = 0 [m] Displacement Y Component = 0 [m] Displacement Z Component = -Movimiento Option = Cartesian Components END END WALL ROUGHNESS: Option = Smooth Wall END END END DOMAIN MODELS: BUOYANCY MODEL: Option = Non Buoyant END DOMAIN MOTION: Option = Stationary END MESH DEFORMATION: Displacement Relative To = Previous Mesh Option = Regions of Motion Specified MESH MOTION MODEL: Option = Displacement Diffusion MESH STIFFNESS: Option = Increase near Small Volumes Stiffness Model Exponent = 10 REFERENCE VOLUME: Option = Mean Control Volume END END END END REFERENCE PRESSURE: Reference Pressure = 1 [atm] END END FLUID DEFINITION: agua Material = Water Option = Material Library MORPHOLOGY: Option = Continuous Fluid END END FLUID MODELS: COMBUSTION MODEL: Option = None END HEAT TRANSFER MODEL: Fluid Temperature = 25 [C] Option = Isothermal END THERMAL RADIATION MODEL: Option = None END TURBULENCE MODEL: Option = k epsilon END TURBULENT WALL FUNCTIONS: Option = Scalable END END END INITIALISATION: Option = Automatic INITIAL CONDITIONS: Velocity Type = Cartesian CARTESIAN VELOCITY COMPONENTS: Option = Automatic with Value U = 0 [m s^-1] V = 0 [m s^-1] W = 0 [m s^-1] END STATIC PRESSURE: Option = Automatic with Value Relative Pressure = 0 [psi] END TURBULENCE INITIAL CONDITIONS: Option = Medium Intensity and Eddy Viscosity Ratio END END END OUTPUT CONTROL: BACKUP RESULTS: Backup Results 1 File Compression Level = Default Option = Standard OUTPUT FREQUENCY: Option = Timestep Interval Timestep Interval = 50 END END MONITOR OBJECTS: MONITOR BALANCES: Option = Full END MONITOR FORCES: Option = Full END MONITOR PARTICLES: Option = Full END MONITOR POINT: Desplazamiento en Z Coord Frame = Coord 0 Expression Value = areaAve(Total Centroid Displacement Z)@Wall Option = Expression END MONITOR POINT: Mesh Quality Coord Frame = Coord 0 Expression Value = minVal(Orthogonality Angle Minimum)@Default Domain Option = Expression END MONITOR POINT: Remesh Coord Frame = Coord 0 Expression Value = minVal(Orthogonality Angle Minimum)@Default Domain \ < 15[deg] Option = Expression END MONITOR RESIDUALS: Option = Full END MONITOR TOTALS: Option = Full END END RESULTS: File Compression Level = Default Option = Standard END TRANSIENT RESULTS: Transient Results 1 File Compression Level = Default Option = Standard OUTPUT FREQUENCY: Option = Timestep Interval Timestep Interval = 10 END END END SOLVER CONTROL: Turbulence Numerics = First Order ADVECTION SCHEME: Option = High Resolution END CONVERGENCE CONTROL: Maximum Number of Coefficient Loops = 10 Minimum Number of Coefficient Loops = 1 Timescale Control = Coefficient Loops END CONVERGENCE CRITERIA: Residual Target = 1.E-4 Residual Type = RMS END INTERRUPT CONTROL: INTERRUPT CONDITION: Interrupt Condition 1 Logical Expression = RemeshingCond Option = Logical Expression END END TRANSIENT SCHEME: Option = Second Order Backward Euler TIMESTEP INITIALISATION: Option = Automatic END END END END COMMAND FILE: Version = 15.0 END SIMULATION CONTROL: CONFIGURATION CONTROL: CONFIGURATION: Configuration 1 Flow Name = Flow Analysis 1 ACTIVATION CONTROL: CONTROL CONDITION: Activation Condition 1 Option = Start of Simulation END END REMESH: Remesh 1 Activation Condition List = Interrupt Condition 1 Geometry File = D:\Simulaciones \ Tesistas\PIG\Caja-Tubo\ICEM-CFX\ICEM-CFX_files\dp0\ICM\ICEMCFD\ICM.t\ in Location = BODY Mesh Replay File = D:\Simulaciones \ Tesistas\PIG\Caja-Tubo\ICEM-CFX\ICEM-CFX_files\dp0\ICM\ICEMCFD\caja.\ rpl Option = ICEM CFD Replay ICEM CFD GEOMETRY CONTROL: Option = Automatic ICEM CFD PART MAP: box Boundary = Wall ICEM CFD Parts List = BOX END END ICEM CFD MESH CONTROL: Option = None END SCALAR PARAMETER: Desplazamiento en Z Monitor Point = Desplazamiento en Z END END END --------------------------------------------------------------------------- I used this tutorial of the EDR company. http://es.scribd.com/doc/73381400/AN...ing-EDR#scribd if you want image of the setup, I can give it to you. |
