November 16, 2022, 08:25 |
Explicit CEL variables
Juan Luis
Rep Power: 13 |
Hi everybody,
Anyone knows how can you use explicit variables in CEL? Or, is it possible to access variables or properties of previous time steps? Thank you. |
November 16, 2022, 16:28 |
Rep Power: 143 |
What do you mean by explicit variables? Example = 10[m/s]+2*Velocity is an explicit variable.
Can you access variables from previous time steps? This is not supported, but there is a unsupported method of doing it: see Update Loop = TRANS_LOOP Why the Trans_Loop trick does not work? No old time value obtained! Note it is pretty unreliable and does not work in every case (that is why it is unsupported) Alternately you can write some user fortran to do it.
November 16, 2022, 16:38 |
Rep Power: 32 |
adding to Glenn's question:
what are you trying to achieve that needs variables at previous timesteps?
November 17, 2022, 09:17 |
Juan Luis
Rep Power: 13 |
I have a CEL expression that have to be evaluated with variables at the previous step. An example of this could be a temperature ON/OFF control.
November 17, 2022, 17:15 |
Rep Power: 143 |
It would be good if you described what you are actually trying to do because there usually is a better way of doing it.
But to answer your question: You cannot do temperature on/off control in a steady state simulation as it will never converge. If you want to do it in a transient simulation you can try the TRANS_LOOP approach or a user fortran routine, as previously suggested.
cel expression |
Mesh displacement failed with User CEL Functions | motorbean | CFX | 2 | July 11, 2022 05:33 |
[swak4Foam] How to define boundary condition variables by using previosly defined variables? | pawlo | OpenFOAM Community Contributions | 8 | September 13, 2020 11:37 |
CFX CEL Expression for Cavitation Modeling | kimotbwb | CFX | 2 | March 28, 2018 03:26 |
CEL vs. USER FORTRAN | Zaktatir | CFX | 0 | February 16, 2013 06:29 |
CEL Position Dependent Variables in CFX-Pre | njw | CFX | 2 | November 20, 2011 05:11 |
