Heavy oil fluid material
Old   October 13, 2015, 16:19
Default Heavy oil fluid material
dfernandez is on a distinguished road
Hi, I would like to know if can model heavy oil in the material section of pre-CFX as water and only change the properties like specific heat, density, thermal conductivity, vicosity ( including an expression dependent on temperature) or any other properties?
How different would this be from including the heavy oil as new material with all the components and fractions..etc.?
Take on account that the purpose is to simulate CHT between the heavy oil and solid heater in the production pipe?
Thanks in advance
dfernandez is offline   Reply With Quote
Old   October 13, 2015, 21:22
If you are happy to model heavy oil as a constant properties liquid then yes, just modifying the parameters you describe is appropriate.
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 06:21
1. Create new material 2. put a static fluid in pipe yulu FLUENT 3 July 6, 2015 23:25
Algorithms for single phase flow equation of oil reservoir fluid aadi.engr Main CFD Forum 0 April 2, 2014 17:01
error message cuteapathy CFX 14 March 20, 2012 07:45
how to define initial velocity of heavy fluid hezheng Siemens 1 May 31, 2004 00:02
