Fluid-Solid interface frame change - Frozen rotor or NONE?
Old   November 28, 2015, 01:05
Jack
zhaitb is on a distinguished road
Thank you, ghorrocks.
Now I am wondering if I want to model the rotating solid domain in a stationary fluid domain, can I set the wall velocity as the rotating velocity for the fluid side of the fluid-solid interface?
(Define the fluid side of fluid-solid domain interface to be moving at the specified velocity)
If not, what is the common practice in CFX to account for this?
Thank you again for your help.
zhaitb is offline   Reply With Quote
Old   November 28, 2015, 04:43
I do not know what you are trying to do so cannot say.
Old   November 28, 2015, 23:54
Jack
Hello Ghorrocks,
Attached is the geometry for meshing. The highlighted part is a rotating coupling with hallow. I intend to model the solid domain in order to take heat transfer into consideration.
In order to model a rotating solid part in stationary fluid, how should I set in CFX? I believe I need a rotating reference frame (set rotating speed for fluid domain), but how should I treat the solid domain? Can I set it as stationary domain, does this reflect actual physical situation?
Old   November 29, 2015, 18:09
Read the documentation about solid regions. It explains the options and their implications.
Modeling Solid and Fluid at the same using Interface BC..Help needed Prince Jassal Main CFD Forum 1 June 12, 2013 06:07
Heat Flux at Internal walls or Fluid Solid Interface Mahi CFX 3 October 1, 2012 03:18
Fluid Solid Interface in Fluent saisanthoshm88 FLUENT 2 July 17, 2012 06:31
Replace periodic by inlet-outlet pair lego CFX 3 November 5, 2002 21:09
CFX4.3 -build analysis form Chie Min CFX 5 July 13, 2001 00:19
