Additional Variable Source Term in CFX
Hi there, I've been trying to do the additional variable source term idea given at http://www.eureka.im/4110.html to deal with problems with recursive CEL in CFX. I tried the other methods suggested but they don't work for me.
So, I'm using this CCL expression: Code:
FLOW: Flow Analysis 1 The exact error is: The object "/FLOW:Flow Analysis 1/DOMAIN:Fluid Domain/SUBDOMAIN:P Subdomain/SOURCES" contains the following object: "wnow" whose name is not in the set of those allowed: "continuity". Note that I've defined the additional variable "wnow" as =w so that I get a 'copy' of w value from previous iteration to be used in present. Please Help. Thanks! :o |
You are posting a short snippet of the command file out of context.
How is the variable/equation wnow defined, and activated on the given domain. Is the definition, and activation compatible to support a source in a subdomain? |
