September 22, 2012, 15:19 |
Question about CFX-pre and CFX-post script
Meimei Wang
Rep Power: 15 |
May I ask do CFX-pre and CFX-post have script to record all my setting so that after I import the mesh(or .res file) I won't need to set them again and by running the script I obtain the setting(or picture) directly?
Best regards, Meimei |
September 22, 2012, 16:33 |
Yes, they have the abilities you mentioned. In the CFX-Pre you can import and export CCL files. In the CFD-post you can save and reuse a state file (.cst file)
September 24, 2012, 21:49 |
Rep Power: 143 |
Pre and Post also have session files which are like recording and playing back user actions.
September 26, 2012, 06:54 |
Meimei Wang
Rep Power: 15 |
I didn't find it. Maybe my CFX doesn't have it. May I ask how to open it? Where's the button?
October 3, 2012, 04:34 |
ali
Rep Power: 15 |
file=>export=>CCL and in your next simulation file=>import=>CCL
October 3, 2012, 10:08 |
#6 | |
Jeremy B.
Rep Power: 13 |
For example, if the number of domains varies, your CCL will define the first X domains but not all of them. (the same with interfaces, boundaries, etc) Otherwise, this method works very well in CFX-pre and CFX-post. |
October 7, 2012, 13:44 |
#7 | |
Meimei Wang
Rep Power: 15 |
Thanks!
October 8, 2012, 00:55 |
Chris DeGroot
Rep Power: 17 |
Yeah the CCL won't have information on transformations. You should try the suggestion of recording a session file.
October 8, 2012, 03:38 |
#9 |
A .cfx format file is a session file. You can use it to do your work!
October 29, 2015, 02:57 |
Scripting single node in CFX
#10 |
Adrian
Rep Power: 10 |
Can I ask you about CFX-post scripting. Is it possible to read ex. temperature from a single node? Have you ever tried to define the parameters to the single node in CFX -pre? may you have same examples? Thanks Adrian |
October 29, 2015, 03:36 |
#11 |
Rep Power: 18 |
Mesh node or arbitrary point in flow domain?
October 29, 2015, 04:35 |
#12 |
Adrian
Rep Power: 10 |
October 29, 2015, 05:37 |
#13 |
Rep Power: 18 |
October 29, 2015, 08:50 |
#14 |
Adrian
Rep Power: 10 |
Thank you. I've just read that Values are stored in the results file at nodes and represent “average” control volume values. Could you tell ma how to get a value from the nodes located for example on the wall? Is kind of selection tool like in APDL? I'd like to select all nodes from the wall.
best regards Adrian Last edited by AdrianCzubajs; October 29, 2015 at 13:41. |
October 29, 2015, 22:38 |
#15 | |
Rep Power: 18 |
October 30, 2015, 13:41 |
#16 | |
Adrian
Rep Power: 10 |
In CFX-Post I can do this with session file (.cse) In CFX-Pre I can use CCL. If I am wrong please let me know. I thought I can select nodes/points from the 'wall boundary condition' and write to file values from this nodes/points. I can write to file (Perl+csv) but how Can I get a value from the nodes/points from the 'wall boundary condition'? Adrian |
Display Modes | |
different CFX Pre and Post mesh region | mactech001 | CFX | 9 | April 11, 2010 21:08 |
No display on CFX Pre and Post | Dipl.-Ing. Jayadi Lukito | CFX | 0 | May 23, 2007 09:30 |
(CFX POST) Rotational Speed | ARJUN | CFX | 9 | July 13, 2006 20:38 |
CFX 10 -pre and -post problams on Linux | Henry Liu | CFX | 3 | June 22, 2006 06:57 |
CFX 5.7 pre | Neser | CFX | 0 | January 27, 2005 11:22 |
