October 30, 2015, 08:18 |
Including Solid wall while post processing
sunil
Rep Power: 13 |
Hello Every one,
I have solved a case where fluid flows inside a tube. For better representation of results I want to include transparent solid wall surrounding the tube (pipe with thickness) in CFD post. Is there any way to do this in CFD post. For example figure please see the attached image http://s26.postimg.org/u2ej0l6m1/CFD_online.jpg Thank you in advance |
October 30, 2015, 09:08 |
Erik
Rep Power: 23 |
Well depending on how extravagant you want to get, (your attached image is much more complex than your description)
You could check the box for your wall boundary in post in the tree at the top, which will color it blue by default. Then you can change the color and transparency. You may be able to do some instance transforming and scaling to give it thickness if you need. For something really extravagant like your attached image, the only thing I can think of is just using that image as a background, and showing the flow streamlines on top of that, and lining them up together. Not ideal I know, just throwing some thoughts out there. Hopefully someone has better ideas than I. Good luck! |
October 30, 2015, 10:01 |
Edmund Singer P.E.
Rep Power: 20 |
You need to embed your pic into the post. Alot of people cant get to outside sites to see that image (me included).
December 25, 2015, 04:34 |
sunil
Rep Power: 13 |
Hello every one,
I have solved this problem. The steps which I have followed are 1. Create your CFD domain mesh (ICEM or WORKBENCH) 2. Create mesh for your solid part also (no need to worry about element quality and all) (ICEM or WORKBENCH) 3. Import both the mesh in CFX-pre and define interfaceface between solid and fluid part 4.Solve it and you will get both the domains in CFD Post Last edited by sunilpatil; December 25, 2015 at 04:36. Reason: spelling mistakes |
Display Modes | |
Divergence in AMG solver! | marina | FLUENT | 20 | August 1, 2020 11:30 |
[ANSYS Meshing] Displaying solid domains in CFD Post without meshing them. | hda | ANSYS Meshing & Geometry | 5 | October 24, 2016 09:26 |
Question about heat transfer coefficient setting for CFX | Anna Tian | CFX | 1 | June 16, 2013 06:28 |
post processing for KIVA | dirga | Main CFD Forum | 5 | April 23, 2009 10:58 |
How To Convert Fluid wall in Solid Wall Boundary Condition | RGN | FLUENT | 4 | March 31, 2009 04:43 |
