Fan modeling in heat convection oven
Old   November 10, 2015, 01:33
Default Fan modeling in heat convection oven
david
chaosgimeng is on a distinguished road
Hi, all
i'm trying to model a simple 'fan' which is used in convective baking oven.
I try to follow the 'cfx manual for flow in an axial trubine stage', but it was to complicated and not enough for explanation.
I just want to find the result of flow outlet by the fan.
Air flows toward the fan middle point in and flows out to side direction (90 degree), not backward
In this situation, i want to know the out flow information(only velocity) in 'vector form' because i'm going to apply this velocity information to another simplified fan modeling (just taking velocity profile information)
It would be a lot of help if anyone could recommend solution in here or provide reference that can be refered.
Also i tried MRF method but it i can'y find much more easy and qualified tutorial to follow. Is there any reference about MRF mtehod, please talk to me.
P.S. Error generated in attaching image so sorry for no image.
Thank you.
chaosgimeng is offline   Reply With Quote
Old   November 10, 2015, 23:37
If you are just using the fan to generate flow in the convective oven and the details of the flow in the fan are not important then use a momentum source term to generate the flow. Then you can add the same momentum as the fan to the flow, but you do not need to model the details of the fan (blades, passages etc).
Or do you want to know the detailed flow inside the fan?
Old   November 18, 2015, 22:12
Erik
evcelica is on a distinguished road
An easier way (to me at least) is to use an outlet at the fans suction side, and an inlet at the discharge side. Make the temperature at the inlet "massFlowAve(Temperature)@FanSuction"
I always found the momentum source to be numerically unstable and required small timesteps or it would blow up.
evcelica is offline   Reply With Quote
Modeling a Fan by the Multiple reference frame (MRF) method in CFX. saisanthoshm88 CFX 11 February 17, 2021 12:30
UDF for Heat Exchanger model francois louw FLUENT 2 July 16, 2010 03:21
Heat transfer, convection, radiation, conduction Sandra H. OpenFOAM 1 March 3, 2010 09:02
heat convection in a forced fluid Daniele COMSOL 0 December 20, 2005 09:09
flow simulation across a small fan jane luo Main CFD Forum 15 April 12, 2004 18:49
