[Sponsors] | |||||
Roland Rakos
Rep Power: 18 ![]() |
Dear All,
Last year, I complated a simulation including a solid discbrake, solid pad and the fluid domain (in CFX 14). The disc was defined as rotating solid domain. The pad was defined as a heat source. The simulation seemed to be very realistic; it was similar to this: http://usercontent2.hubimg.com/4026495_f260.jpg Now, I tried to complate this simulation again but it doesn't operate well. The settings are same to the previous model but the result show that the disc (solid) are not in rotating. The temperature of disc is very high near by pad but the "smear" of temperature doesn't occur along disc. It seems to me that the disc is a stationary domain, it is not in rotating. I try it in CFX 15, CFX 14 but the results are same... What can be the reason? Thanks; Roland |
Rep Power: 146 ![]() ![]() ![]() ![]() |
Rotating solids is in V15, but not V14. So I would expect the V14 result to not include rotation. If you got the other way around then that is very strange.
Roland Rakos
Thank you for your answer. My main problem that the result (temperature distribution at disc) is not ok in v15 at the moment.
Have you had a look at the documentation? Here's a quote from it:
A rotating solid can be modeled in two different ways: Moving reference frame and solid motion off. If a stationary domain surrounds the solid, a frame change model is required to account for the reference frame changes. Best accuracy will be achieved with a Transient Rotor Stator interface, but this requires a transient simulation. Stationary reference frame and solid motion on. This activates the term involving as mentioned above. If a stationary domain surrounds the solid, no frame change model is needed, so it is possible to use a steady state simulation. |
#5 | |
Roland Rakos
thank you for your help. Based on your instructions, the simulation operates well. Finally one question: In case of using of "solid motion", it is possible to apply the "boundary advection". What does it meann exactly? Based on CFD help, it was not clear for me. Thanks; Roland |
It is not entirely clear, is it? To be honest, I am not sure.
I would just try the different options and see what they do. |
Roland Rakos
I complated some test cases to invastigate the solid motion option. Based on my results, I have found a new problem. If I investigate a simple fully filled disc then the temperature distribution is OK at the disc. BUT: If I investigate a more complicated brake disc including holes, ribs, blades etc, then the calculations go into divergence in the second iteration. The temperature values are around 0 [K] in all nodes. I checked the BC's more times. I tried to use some tricks; - gradual RPM increasing for disc - initialization from a converged non rotational disc - etc etc But nothing result. It seems to me, that the solid motion option is very similar to the wall velocity option. If the wall velocity is parallel with the wall then the result is OK. But if the model includes velocity component which is perpendicular to the motion wall then it will result non realistic temperature values. What do you think about this problem? Is it possible, that the solid motion option can be used for filled disc geometry only? Thanks Roland |
Sounds possible.
Have you tried the other approach discussed in the documentation for modelling solid rotating bodies? |
#9 |
Roland Rakos
As far as I know, these options are available in CFX to investigate brakedisc:
- rotation domain in solid in steady =>> it doesn't operate - solid motion in steady =>> it doesn't operate - rotation domain in transient rotor stator =>> it operates well but it can not be applied in case of high mesh element number. It seems to me; there is not possible to solve this problem in steady state case... |
#10 |
I know ANSYS did work on this to make rotating solid domain models easier in V15. I am not sure whether that applied to transient runs only or steady state models as well.
You might need to ask ANSYS support for advice here. |
#11 |
Roland Rakos
I had a short consultation with our support. Based on this, at the moment, there is one method which calculate the disc rotation and the heat advection exactly: a transient simulation
![]() The solid motion option can be used only for fully rotational symmetry part, etc. a filled disc, cylinder... |
| Thread Tools | Search this Thread |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| Continuous casting simulation problem | luke.christ | FLUENT | 6 | November 24, 2020 08:14 |
| Problem with VOF and rotating disc in Fluent | Ludvig | FLUENT | 1 | March 13, 2014 20:57 |
| simulation problem -- convection BC | pras | FLUENT | 4 | January 30, 2013 11:41 |
| how do i model a brake disc in gambit? | joshie | FLUENT | 1 | September 16, 2009 09:43 |
| Heat convection into a Disc brake | Robin Windram | FLUENT | 0 | February 20, 2009 08:03 |
