[Sponsors] | |||||
Liezl Tan
Rep Power: 12 ![]() |
I am trying to simulate the pressure around a low-rise building with eaves and openings. In the case where there's NO OPENING yet, (i.e. wind flow around a closed building), I expect no relative pressure developing inside the building (UNDEFINED).However, as I accidentally probed inside the building and near the walls and roof, I am getting pressure and velocity values. So, to investigate further, I tried plotting the pressure and velocity contour on a cutting plane and you can see that in the attached picture. Can someone kindly explain why so? By the way, I didn't use the ENCLOSURE tool since it requires a certain distance between the building and the ground. So I simply created a box wherein its ground coincides with the base of the building then used BOOLEAN to create the Fluid Environment. I initially thought this was the problem so I ran another case using Enclosure with 5 mm gap between the base and the ground. Still I'm getting pressure and velocity values inside the building near the walls. My ultimate concern is if this issue will affect the pressure values near the walls and roof inside the building when I'm considering openings. Thank you for taking time to help out! |
Maxim
Rep Power: 14 ![]() |
could you also post a picture of your mesh, please? Have you defined the boundaries around the house correctly? As a 'wall'?
Rep Power: 146 ![]() ![]() ![]() ![]() |
Have you defined the house as an immersed solid? If so you should not do that, it should be a cavity in the mesh domain.
Liezl Tan
Hello Maxim,
I will get back to you with the picture of the mesh... but with regards to the boundary condition, YES i did assign a WALL - No Slip . |
Liezl Tan
Hello Ghorrocks,
This can be found in the CFX-Pre right? I looked at the Domain Type and I already defined it as Fluid Domain (other options include solid, porous and immersed solid). |
| Thread Tools | Search this Thread |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| Boundary conditions for flow in nozzle | kgevers | FLUENT | 0 | July 26, 2015 13:46 |
| Boundary condition for transonic flow over slender body | rock.senthilkumar | FLUENT | 0 | February 19, 2013 06:26 |
| How to visualize the solid body in multiphase flow grid? | asoltoon | OpenFOAM Post-Processing | 2 | February 2, 2013 13:40 |
| Turbulent flow over a blunt body Error Message | pradon16 | FLUENT | 0 | July 27, 2012 17:31 |
| Flow around the ahmed body (large eddy simulation) | Benzamia | CFX | 0 | February 26, 2007 06:03 |
