Independence of solution
I compare two solutions with probes on a significant number of points. Is it correct if we do an independence of the solution for several parameters and for a case, the number of points used for comparison is different because of the processing time to capture data at these points is very long ? Thank you for your help ! |
I cannot say as I do not know the details of what you are doing.
