User Fortran script failures
Old   January 11, 2016, 08:01
Default User Fortran script failures
honcho62 is on a distinguished road
Hi everyone,
I'm trying to implement a user subroutine that applies momentum at specific locations in the mesh. I'm using the MomentumSource1.F and ucf_template.F as a guide.
One of the things I need are matrices, I've done a little bit of fortran tutorials before starting on this but they seem pointless.
For instance I thought I should define a matrix like
real dimension(4,4) :: MyMatrix
or
real (kind=ikind),dimension(4,4) :: MyMatrix
but when I compile it using cfx5mkext and pgf95 it says there is a syntax error in this line. Are there different rules for these types of code?
honcho62 is offline   Reply With Quote
Old   January 11, 2016, 09:02
Lance
Lance is on a distinguished road
In my Fortran code I define arrays as
 REAL mk(3,10)
Im not sure if higher dimensions work differently, but this works as intended.
Lance is offline   Reply With Quote
Old   January 12, 2016, 02:46
thanks for the answer.
the definition actually does work but you need to put the comma after REAL. So that's solved I guess.
cfx-pre, fortran, user subroutine
CFX User Fortran: Particle User Sources hustxinxin CFX 0 March 8, 2012 08:37
CFX User Fortran: Particle User Sources hustxinxin CFX 0 March 8, 2012 08:31
Particle Transport & Termination Control with User FORTRAN Julian K. CFX 3 January 12, 2012 09:48
Comparison between C/C++ and Fortran? rick Main CFD Forum 45 September 6, 2011 00:52
User Fortran and interior node information John CFX 0 August 26, 2008 22:24
