Problem with setting of boundary conditions (rotating + stationary)
Old   February 5, 2016, 04:40
Default Problem with setting of boundary conditions (rotating + stationary)
Aleksandr
metaliat93 is on a distinguished road
I have problem with BC. I prepared 3 domains in ICEM and import into Pre CFX. 507983532.png
First domain it is inlet pipe, Second - rotating vane machine, third - open around domain with atmosphere pressure. 507983179.png this error getted in solver
I thing, I had problem with boundary: hub wall of vane machine and boundary of open domaine.
This my mesh
This CCL file
metaliat93 is offline   Reply With Quote
Old   February 5, 2016, 05:41
1. Are you modelling the blades as a solid? You do not model the rotating machine (unless you are modelling heat transfer). You only model the air around the rotating machine.
2. The error message states you have not defined a frame change model at the interface. You will need to do this. Have a look at the CFX tutorials for how they set up frame change interfaces.
Old   February 5, 2016, 05:50
Aleksandr
I don t modeling solid blades, it is only volume of gas
this my settings of frame model
Old   February 5, 2016, 05:52
OK, good. Can you post an image of your full geometry? Where are the 3 domains?
I cannot download your mesh file, so just post an image on the forum.
Old   February 5, 2016, 05:55
Aleksandr
Old   February 5, 2016, 05:57
Aleksandr
2. The error message states you have not defined a frame change model at the interface. You will need to do this. Have a look at the CFX tutorials for how they set up frame change interfaces.[/QUOTE]
With this setting i had error ' | ERROR #001100279 has occurred in subroutine ErrAction. |
| Message: |
| Floating point exception: Zero divide '
Old   February 10, 2016, 03:46
Aleksandr
you can download files mesh in my first post
Old   February 10, 2016, 06:52
There is a massive range of mesh sizes in this simulation. This is likely to cause a problem. You are going to need to run double precision to get this to converge, and even then you might have a problem.
Does the exit domain need to be so big?
Old   February 10, 2016, 11:31
Aleksandr
| Message: |
| Floating point exception: Zero divide |
I used double precision
Old   February 10, 2016, 18:25
Overflow is an FAQ: http://www.cfd-online.com/Wiki/Ansys...do_about_it.3F
But in your case the massive difference in mesh sizes will be contributing to this. As I said before - do you need such a large outlet domain?
Old   February 12, 2016, 09:26
Aleksandr
yes, i need such a large outlet domain, because I analyse area of spreading solid particles.
Domain with name "Open" needs only for distribution particles. I solved the problem of BC. But I have a next problem with to using "dispersed solid".508605868.png
"In Analysis 'Flow Analysis 1' - Domain 'Inflow': At least one continuous phase must be defined."
Can you advise to me tutorial?
Old   February 12, 2016, 09:28
Aleksandr
I solved without solid particle
Setting Up a Single Rotating Reference Frame Problem aja1345 FLUENT 1 July 31, 2015 12:24
Difficulty In Setting Boundary Conditions Moinul Haque CFX 4 November 25, 2014 18:30
Setting rotating frame of referece. RPFigueiredo CFX 3 October 28, 2014 05:59
CFX13 Post Periodic interface EtaEta CFX 7 December 8, 2011 18:15
boundary conditions for a rotating wind turbine problem amoolraina FLUENT 0 December 22, 2010 11:40
