December 30, 2018, 06:48 |
CFX parallel computing questions
gengchen
Rep Power: 7 |
Hello, everyone, thanks for your attention! I use HPC for CFX calculation. I'm a new learner using 'ssh -X node01' to open CFX and my questions are as follows:
1. I can only use one node for calculation, how am I supposed to use multiple nodes? 2. In each node, there are 2 CPUs and each has 10 cores, but the total processors are 40. So what is the maximum number of processes I may use? 20 or 40? 3. when I use uptime to check current cpu load it's very high. Is there a maximum uptime value limit? I'm afraid that if the load is too high the server maybe overheated and get damaged. That's 3 questions I want to ask you guys. Thanks again! |
December 31, 2018, 06:04 |
Rep Power: 143 |
1) Look in the CFX documentation and setup manuals for distributed parallel setup.
2) It appears you have 20 physical cores and 20 virtual cores. The virtual cores are from hyperthreading. Hyperthreading does not work with CFX so do not use the virtual cores. You can use them if you like, there is nothing stopping you, but the simulation speed will be poor. CFX only runs fast on physical cores. 3) You can set CFX to run for specified times if you like. But I have never heard of a HPC cluster which cannot run at full speed continuously. HPC clusters are intended to run at full speed continuously. So you will be fine unless you have bought cheap computers or overclocked them. Also make sure there is adequate air flow around them so they can cool properly.
January 1, 2019, 00:39 |
gengchen
Rep Power: 7 |
SIMULATION CONTROL: EXECUTION CONTROL: PARALLEL HOST LIBRARY: HOST DEFINITION: mgmt Installation Root = /home/App/ansys_inc/v%v/CFX Host Architecture String = linux-amd64 END # HOST DEFINITION mgmt HOST DEFINITION: node01 Installation Root = /home/App/ansys_inc/v%v/CFX Host Architecture String = linux-amd64 END # HOST DEFINITION node01 HOST DEFINITION: node02 Installation Root = /home/App/ansys_inc/v%v/CFX Host Architecture String = linux-amd64 END # HOST DEFINITION node02 HOST DEFINITION: node03 Installation Root = /home/App/ansys_inc/v%v/CFX Host Architecture String = linux-amd64 END # HOST DEFINITION node03 HOST DEFINITION: node04 Installation Root = /home/App/ansys_inc/v%v/CFX Host Architecture String = linux-amd64 END # HOST DEFINITION node04 HOST DEFINITION: node05 Installation Root = /home/App/ansys_inc/v%v/CFX Host Architecture String = linux-amd64 END # HOST DEFINITION node05 END # PARALLEL HOST LIBRARY END # EXECUTION CONTROL END # SIMULATION CONTRO |
January 1, 2019, 00:40 |
gengchen
Rep Power: 7 |
The problem has been solved and I learn a little more about HPC, thank you sir and happy new year!
cfx, hpc cluster, parallel calculation |
Remote cluster parallel solve without master, Ansys CFX 14.5 | aaguirre | CFX | 4 | January 27, 2015 09:15 |
Parallel Problem of CFX 14.5.7 on a Intel Xeon 2690V2 computer with Win7 x64 OS | BruceWen | CFX | 14 | September 16, 2014 19:25 |
Parallel computing debate on transient simulations | JuPa | CFX | 3 | December 17, 2013 05:22 |
CFX parallel hp MPI problem | fluidmechanics | CFX | 5 | June 19, 2013 19:05 |
correction number and parallel computing | psosnows | OpenFOAM Bugs | 5 | June 17, 2013 20:56 |
