Error Message "Insufficient space for array LNOD"
Hi!
I’m running a transient simulation with a moving mesh with approximately 950k elements on 6 cores. And it works fine for the first 30 time steps but then it crashes and it gives this error message: ERROR #004100008 has occurred in subroutine FINDL. Message: Insufficient space for array LNOD. Anyone has some idea of what the problem can be? :confused: Am I using to many cores for a to course mesh? |
There is no sufficient memory for an internal array.
Try providing more memory at the start of the run. In the ANSYS CFX Solver Manager check for the memory overrides/factors. Hope the above helps, |
1 Attachment(s)
Is’t this setting you mean? |
A quick update about the problem, changing the memory overrides/factors didn’t help.
But got a reply from Ansys saying: “Switch to Independent Partitioning (coupled is the default/Automatic)” and this seems to work for me. :) |
