March 1, 2016, 07:21 |
Conservative temperature
Rep Power: 10 |
Hello all,
I am doing a transient thermal simulation and i am having some trouble to understand what I am seeing. The simulation is a thermal study of valves. The heat transfer between the boundaries is set to 'conservative heat flux' all around the ring. In the first picture, one can see the temperature set to 'hybrid' and the contour seems to be pretty symmetrical. In the second image, the temperature is set to 'conservative' and it is not symmetrical anymore. I understand the difference between conservative and hybrid values but i am having trouble to understand why the conservative values are not symmetrical. I agree the values of temperature should be different from hybrid to conservative but the contours should be similar no? Do you have any ideas ? Thanks |
March 1, 2016, 19:19 |
Rep Power: 143 |
The conservative values will be mesh sensitive - if the mesh is different then the conservative values will change but the hybrid values will not. Does this explain it?
March 2, 2016, 11:51 |
Rep Power: 10 |
Yes, i think I get it. It makes sense that it is mesh dependant since the conservative values are calculated based on the control volume.
Cheers Glenn |
unexpected constant Temperature on a clip surface | Sungki | OpenFOAM Running, Solving & CFD | 0 | August 4, 2015 04:50 |
Radiation interface | hinca | CFX | 15 | January 26, 2014 17:11 |
An error has occurred in cfx5solve: | volo87 | CFX | 5 | June 14, 2013 17:44 |
Is wall ajacent temperature equal to conservative temperature of the wall? | shenying0710 | CFX | 8 | January 4, 2013 04:03 |
monitoring point of total temperature | rogbrito | FLUENT | 0 | June 21, 2009 17:31 |
