Rep Power: 15 ![]() |
how can I get results on how long it takes between inlet and outlet? I want to optimise some baffles, so the fluid meanders around as long as possible |
particle travelling time I guess
Rep Power: 145 ![]() ![]() ![]() ![]() |
You can use particle travelling time if you are using a particle model. You can also do this without a particle model by putting steamlines from the inlet to outlet and then colouring the streamlines by time.
nice to know.
Can make the particles to show a particle travelling time, then the global scale shows the max time. Will try the streamlines, if I could get travellinng time from there, don't have to bother with particles |
Display Modes | |
Extrusion with OpenFoam problem No. Iterations 0 | Lord Kelvin | OpenFOAM Running, Solving & CFD | 8 | March 28, 2016 11:08 |
Pressure inlet vs outlet position, transient, time dependent pressure and gravity | silent2608 | FLUENT | 0 | February 6, 2016 10:19 |
Micro Scale Pore, icoFoam | gooya_kabir | OpenFOAM Running, Solving & CFD | 2 | November 2, 2013 13:58 |
same geometry,structured and unstructured mesh,different behaviour. | sharonyue | OpenFOAM Running, Solving & CFD | 13 | January 2, 2013 22:40 |
Terrible Mistake In Fluid Dynamics History | Abhi | Main CFD Forum | 12 | July 8, 2002 09:11 |
