Free surface- Sloshing
Old   February 1, 2016, 04:07
Default Free surface- Sloshing
hossein
hossein_sml is on a distinguished road
I am trying to simulate free surface in moving (rotating) cube ( water -sloshing)
unfortunately convergence is terrible. and the free surface's behavior is not logical.
As shown in below image, at start of movement a hollow is creating in surface.
After some steps it acts properly,
but it again become completely wrong.
I really need help!
What is wrong?
I have checked all parameters.
hossein_sml is offline   Reply With Quote
Old   February 1, 2016, 05:42
First of all - make sure your convergence is tight enough, your mesh is high quality and your time step size is small enough. You won't get anything sensible unless you do this.
The default free surface settings in CFX are not always optimal. In fact in same cases it can generate large spurious flows adjacent to the free surface which generates artefacts like this.
I recommend you look at all the free surface modelling parameters and adjust them all and see what helps and what does not. Doe this on a small mesh for a small number of time steps - enough to see the problems you are seeing starting up. This means you will have a few dozen simulations to do, so script them up to run together. You will find there are a few parameters which affect the model you are doing and you can normally find some settings which work better than the default values.
I have done this a few times for free surface modelling work I did and it improved the model a great deal. But it is different for each model so you really need to find out what works for you.
Old   February 24, 2016, 09:55
hossein
Dear Glenn
I have checked mesh sensitivity. and mesh is good.
I have set convergence tight enough, but it is not converging.
RMS: 1e-8
Max Coeff Loop : 50
Also time step is small enough
I have checked all parameters. I realy do not know what i should do!
Old   February 24, 2016, 17:23
Your result is typical of numerical instability, so something is making it go unstable. You have missed something important.
Really? Which parameters have you checked? In my experience the free surface parameters can make a big difference and are likely to be what is causing this problem so I suspect you have missed something important.
Old   March 5, 2016, 12:03
hossein
I should say that at first i tried to model free surface in a cube which was rotating on its corner. The results were OK.
But when I used that setting in cube which is rotating along center of its base side, it is not converging.
What is problem?
Old   March 5, 2016, 12:04
hossein
which setting you need to know to help me?
Old   March 6, 2016, 17:27
I have already said what is likely to be causing your problems in my experience.
free surface, sloshing
[Gmsh] Problem with Gmsh nishant_hull OpenFOAM Meshing & Mesh Conversion 23 August 5, 2015 02:09
Multiphase flow. Dispersed and free surface model Luis CFX 8 May 29, 2007 18:13
Free Surface Modelling (sloshing) fakir CFX 0 November 23, 2006 02:23
free surface display carno Siemens 4 October 7, 2005 01:03
CFX4.3 -build analysis form Chie Min CFX 5 July 12, 2001 23:19
