March 8, 2016, 03:31 |
HIGH Pressure on Domain
Marcin
Rep Power: 12 |
Hello
I have a question how to model a high pressure on domain 14 bars ?? When I make reference pressure 14 bars I didnt see a difference beetween this pressure and one bar on heat transfer process. Cooling system of the 800 C Bar Best regards
Quick Tips and Tricks, Tutorials FLuent/ CFX (CFD) https://howtooansys.blogspot.com/ |
March 8, 2016, 03:51 |
Thomas
Rep Power: 11 |
Show on an image what are you thinking about in more details.
March 8, 2016, 08:30 |
Marcin
Rep Power: 12 |
I have one steel rod in fluid domain (air)
I need to make heat transfer depend on pressure on domain. If i define 14 bars or I define 1 bar I didnt see a difference (when I define on domain on reference pressure) Best regards
March 8, 2016, 17:52 |
Rep Power: 143 |
If you are saying that you are comparing an atmospheric pressure model and a 14 bar model and are getting the same heat transfer - have you taken the higher pressure into account for the material properties? The density is much higher. You could also use a compressible gas model (eg ideal gas) and it would account for it automatically.
March 9, 2016, 02:33 |
Marcin
Rep Power: 12 |
Thanks Ghorrocks a lot ! Your answer was very helpful.
So I define ideal N2 gas with thermal energy solver and sst for turbulence. And I have difference beetwen 1 bar and 14 bars Best regards
sonicFoam - pressure driven pipe: flow continuity violation and waveTransmissive BC | Endel | OpenFOAM Running, Solving & CFD | 3 | September 11, 2014 16:29 |
Floating point exception: Zero divide | liladhar | CFX | 11 | December 16, 2013 04:07 |
CFX domain comparison | Kiat110616 | CFX | 4 | April 3, 2011 22:43 |
Multicomponent fluid | Andrea | CFX | 2 | October 11, 2004 05:12 |
Hydrostatic pressure in 2-phase flow modeling (CFX4.2) | HB &DS | CFX | 0 | January 9, 2000 13:19 |
