time scale related to mesh size
Old   May 6, 2016, 11:08
Default time scale related to mesh size
yaseen
yaseen wsu is on a distinguished road
hello
I simulated free surface flow using coarse mesh with time scale 0.025 sec after about 600 iteration it reaches my residual (10e-4), but fir the same model with fine mesh and the same time scale, after 1500 iteration it does not reach the required residual. does physical time scale related to mesh size??
thanks
yaseen wsu is offline   Reply With Quote
Old   May 7, 2016, 00:40
You usually need a smaller time step with finer meshes. It does not necessarily scale, but that is often a useful starting point. Use adaptive time stepping to find the necessary time step size and it takes care of this for you. Also, finer meshes usually are harder to converge as they have less numerical dissipation and are therefore less numerically stable. So you are getting the expected behaviour.
Old   May 7, 2016, 02:30
yaseen
thanks a lot
but my case is steady state, is there time step adaption in steady state??? I only see time scale
Old   May 7, 2016, 06:01
In steady state your are free to adjust the time step size as required. Make it bigger if it is converging consistently but slowly, make it smaller if it is diverging or inconsistent convergence.
Old   May 9, 2016, 03:55
yaseen
dear glenn
I used automatic time scale with time scale factor 0.5 sec, but there are fluctuation in the equation residuals and not reach 10^-4 as shown in in fig. what does that reason?? because when I use 1 sec as time scale factor it gives error, is that due to small time or large tome scale, thanks
https://drive.google.com/open?id=0B3...HctaFA1TkwxeUE
Old   May 9, 2016, 08:01
I know you have said you have already read this, but this thread really is covered by this FAQ: http://www.cfd-online.com/Wiki/Ansys...gence_criteria
You really need to consider the issues it discusses.
Old   May 9, 2016, 16:53
Opaque will become famous soon enough
Have you selected the option to output the equation residuals to the results file ?
One the equation residuals are in the results file, you can post-process them to find out where the maximum residual for each equation is located. Look carefully at that region of space for mesh quality issues, or specific flow features that may require a better mesh.
A bad mesh (coarse or fine) could prevent convergence of the iterative procedure.
Hope the above helps,
Opaque is offline   Reply With Quote
decomposePar problem: Cell 0contains face labels out of range vaina74 OpenFOAM Pre-Processing 37 July 20, 2020 05:38
dynamic Mesh is faster than MRF???? sharonyue OpenFOAM Running, Solving & CFD 14 August 26, 2013 07:47
OF 1.6 | Ubuntu 9.10 (64bit) | GLIBCXX_3.4.11 not found piprus OpenFOAM Installation 22 February 25, 2010 13:43
Modeling in micron scale using icoFoam m9819348 OpenFOAM Running, Solving & CFD 7 October 27, 2007 00:36
IcoFoam parallel woes msrinath80 OpenFOAM Running, Solving & CFD 9 July 22, 2007 02:58
