Use CCL file to add subdomain without overwriting existing setup |
May 10, 2016, 10:22 |
Rep Power: 10 |
Hi everyone,
I have a script that automates some of the setup in CFX-Pre and I'd like to expand it. It's basically a matlab script that generates a CCL file that you can load in CFX-Pre. I want to add a subdomain with certain pre-sets. In this case boundary conditions and the domain are already pre-defined, this way you could apply it to general case. I have added all the info necessary for the subdomain to the CCL but when I load it in CFX-Pre it overwrites the pre-defined boundary conditions and domain info, because they're not in the CCL file. So I can either add all that info, which defeats the purpose, or find a way to add this subdomain without overwriting the pre-defined boundary conditions and such. Is this possible? Thanks |
May 10, 2016, 11:12 |
Peter
Rep Power: 14 |
Have you tried to skip the &replace command in the ccl
FLOW: Flow Analysis 1 &replace DOMAIN: Fluid Coord Frame = Coord 0 Domain Type = Fluid Location = Assembly ... |
May 10, 2016, 15:29 |
Rep Power: 10 |
I don't have the &replace in there it's just plain.
NVM: I didn't notice the Import Method options when you open a CCL file Last edited by honcho62; May 11, 2016 at 05:03. Reason: solved it |
May 11, 2016, 11:51 |
Rep Power: 32 |
Are you appending or replacing the additional CCL to the existing CCL ?
If you use the user interface, and import the CCL there is an "Import Method" setting you must select (defaults to Replace). If you use a session file, you must look at the import command and select the Import Method to either replace, or append your "CCL fragment" Hope the above helps, |
[swak4Foam] groovyBC in openFOAM-2.0 for parabolic velocity bc | ofslcm | OpenFOAM Community Contributions | 25 | March 6, 2017 10:03 |
[swak4Foam] swak4foam building problem | GGerber | OpenFOAM Community Contributions | 54 | April 24, 2015 16:02 |
SparceImage v1.7.x Issue on MAC OS X | rcarmi | OpenFOAM Installation | 4 | August 14, 2014 06:42 |
pisoFoam compiling error with OF 1.7.1 on MAC OSX | Greg Givogue | OpenFOAM Programming & Development | 3 | March 4, 2011 17:18 |
ParaView Compilation | jakaranda | OpenFOAM Installation | 3 | October 27, 2008 11:46 |
