ICEM OR TURBO-Grid
hi,
I would like to meshing runner blades, can you suggest the best software meshing between Icem and turbo-grid thanks |
The best software is the one you can use successfully to get the job done. So arrange a trial of both of them and give them a go at doing the task you need to do. Then you will find out for yourself which software is best for your task.
TurboGrid has a nicer GUI. In case you don't have any meshing experience, you will probably achieve results more quickly with TurboGrid.
