Free surface/open channel flow over a circular plate |
May 18, 2016, 03:48 |
Mujahid Badshah
Rep Power: 10 |
Hi All,
I want to model the water flow over a circular plate placed at the mid depth and width in a rectangular channel. The top surface of the channel is open to amosphere.The purpose of the study is to demonstrate that the far wake generated by CFD simulation of the plate has similar characteristics to experimental data. The parameters of the model are as under: Domain: i. Rectangular channel [Length: 5m, width: 1.37m, depth: 0.3m] with top surface open to atmosphere. ii. A free surface is required to be modelled at 0.3 m water depth, with 0.15m air modelled above. Plate: Dia 0.1m, located at 2m from inlet at mid depth and width. Fluids: i. water: Incompressible fluid ii. Air: Ideal Gas Multiphase Control: Homogenous coupled free surface Turbulence Model: SST Inlet: Experimental values of velocities, experimentally derived k and ε. Bottom and Two side Walls: No Slip Condition – Smooth Wall Outlet: Static pressure 0 Pa, Free surface height 0.3 m – 0.0012 m Top: Opening, Air, 0 Pa, Zero turbulence gradient. I have implemented all the settings but i am facing a few problems in impleminting the following settings in CFX: Question#(1). What should be the height of the geometry of my fluid domain? Should it be 0.3m (equal to the depth of water) or 0.3+0.15m (equal to depth of water plus the water column above the free surface)? Question#(2): How to specify the free surface height at the outlet boundary with 0 Pa static pressure in CFX? I have gone through CFX tutorial 9, Free surface flow over a bump, but am unable to correlate? |
May 18, 2016, 10:55 |
Mujahid Badshah
Rep Power: 10 |
How to specify the free surface height at the outlet? other conditions are static pressure 0 Pa.
Boundary condition problem for open channel flow | Andy | CFX | 9 | June 11, 2016 07:20 |
Open channel flow with submerged outlet | Fonta | Fluent Multiphase | 0 | September 30, 2013 08:04 |
benchmark: flow over a circular cylinder | goodegg | Main CFD Forum | 12 | January 22, 2013 11:47 |
pressure outlet (open channel flow) | Willem Brantegem | FLUENT | 2 | April 4, 2007 02:40 |
Free convection flow over vertical flat plate | Polly | CFX | 0 | February 11, 2003 02:51 |
