May 18, 2016, 22:10 |
How to change boundry contidion in CFX-pre
Ian
Rep Power: 12 |
hello,i have a confused problem about boundry condition ,i want to simulate water flow in pipelines, i want to make a roundess wall be seted as wall condition,and wall condition changed into inlet condition several seconds ,how to realize this in CFX-Pre,thank you !
May 19, 2016, 06:31 |
Rep Power: 143 |
I do not understand your question. But if you are asking how can you change a boundary condition type during a run - the simplest way is to stop the run, change the boundary condition to the new type and restart the run using the first run as an initial condition.
May 19, 2016, 20:14 |
Rep Power: 13 |
do you mean, while the simulation is running, i.e. transient? Then flow into one inlet stops (closed by valve) and another wall becomes an inlet (opened by valve) ? Maybe make 2 inlets and make the massflow time dependant? So one goes to 0 and the other from 0 to something?
No idea, if you can change something frim inlet boundary condition to wall. If something is defined as inlet and later on something wants to flow out of the inlet, the solver will place a wall there and give you a warning. Not the nicest way to do things, but that would work. |
Only two turbulence options available in CFX Pre | Jack001 | CFX | 5 | March 30, 2016 02:47 |
air ideal gas in CFX Pre | wangy1767 | CFX | 9 | October 1, 2012 07:55 |
CFX Pre Domains for centrifugal pump | MechKim | CFX | 1 | September 24, 2012 08:06 |
Setting material properties - CFX Pre | cavani | CFX | 6 | January 27, 2011 19:52 |
Problems with adding two meshes together in CFX Pre | peterputer1 | CFX | 2 | September 23, 2009 08:08 |
