May 30, 2016, 23:07 |
The Coupled System of Equations
Rep Power: 11 |
Can somebody explain the notation of the system of equations written in CFX theory guide ?
I don't understand the double notation, subscrit and superscript ... Last edited by MissCFD; May 31, 2016 at 08:28. |
May 30, 2016, 23:15 |
Rep Power: 11 |
May 31, 2016, 10:50 |
Rep Power: 32 |
nb stand for (N)eigh(B)ors
i stand for equation_i the equation reads as "sum around the neighbors of its influence coefficients on i times its variable value is equal to b_i" Those coefficients include the advection, diffusion and other physics interacting between "control volume_i" and its neighbors.. Note the equation may be written in multiple forms where phi can be the value of the solved variable, or the iterative correction to the variable. Based on the interpretation of phi, b can be the source or the residual of the equation. Hope the above gives some context. |
May 31, 2016, 14:47 |
#4 | |
Rep Power: 11 |
I'm not sure to visualize, so can you tell me if this notation means the same ? Does this correspond to system equations for one node ? |
May 31, 2016, 21:04 |
Rep Power: 32 |
Assuming "i" stands for node number, and "nb" includes all the other influencing "i"s (say j) around "i", your are correct.
May 31, 2016, 22:43 |
#6 | |
Rep Power: 11 |
(1) & (2) And, this equations (1 or 2) is written for all the nodes of mesh, so we obtain i times this equation and this is what forms the matricial system ? |
June 1, 2016, 14:12 |
Rep Power: 32 |
I would read them as equivalent
SU2 in Euler form coupled with BL equations | francescofaggiano | SU2 | 0 | May 4, 2016 04:05 |
coupled equations: prediction correction method | zaynab | Main CFD Forum | 0 | November 12, 2015 05:49 |
Solver for system of hyperbolic equations | treima | OpenFOAM Programming & Development | 1 | October 21, 2012 09:34 |
problem with gradient as source term in coupled equations | Cyp | OpenFOAM Programming & Development | 0 | August 16, 2010 13:12 |
CONSERVATION EQUATIONS IN NONINERTIAL SYSTEM!!! | zhang zhanwang | Main CFD Forum | 0 | August 17, 1998 07:38 |
