Profile transformation method and Frozen rotor method
Like Tree1Likes
  • 1 Post By Opaque
Old   May 24, 2016, 00:35
Default Profile transformation method and Frozen rotor method
misagh
misagh is on a distinguished road
what is the difference between unsteady profile transformation method and steady frozen rotor method? since in both of them the profiles
across the interface are stretched or compressed by the pitch-ratio.
How does profile transformation method take into account the unsteady(transient) behavior of Rotor- Stator?
thanks in advance
misagh is offline   Reply With Quote
Old   May 24, 2016, 09:02
Opaque will become famous soon enough
It is probably better to separate one thing from another..
Profile transformation == profile stretching
Frozen Rotor vs Rotor Stator == Fixed Interface|Relative Configuration vs Sliding Interface|Variable Configuration
Profile stretching is applied to both interfaces. The unsteady term is always applied to the equations for transient simulations.
Hope the above helps,
Opaque is offline   Reply With Quote
Old   May 24, 2016, 09:45
misagh
Thanks for your reply.
What do you mean by "Frozen Rotor vs Rotor Stator == Fixed Interface|Relative Configuration vs Sliding Interface|Variable Configuration"
Did you mean that the transient terms in only applied to the profile transformation method?(and not to the frozen rotor or stage?)
Old   May 24, 2016, 11:55
I clearly stated they are separate topics
Transient simulations always include transient terms for all equations regardless of interface type
Profile transformation always stretches the profile, and it is applied at Frozen Rotor and Rotor-stator interfaces regardless of simulation type.
Frozen rotor is an interface type where the relative position of the domains on either side of the interface is maintained FIXED.
Rotor stator is an interface type where the relative position of the domains on either side of the interface is changing as the rotor moves every time step.
Hope the above is a better version of the previous message.
chongbazh likes this.
Old   May 24, 2016, 12:21
misagh
Thanks a lot for your clarification.
