How much Y+ is enough in K-e model?
Like Tree4Likes
  • 1 Post By ghorrocks
Old   June 13, 2016, 23:36
Default How much Y+ is enough in K-e model?
Aja
aja1345 is on a distinguished road
I am running an axial turbine with RNG K-e turbulence model. Wall Function is scalable and Y+ contours are as follows: (please see range of Y+-I enable clip to range)
1. Is there any problem in these contours?
2. How much Y+ is enough in K-e model? What range is Y+ in K-e model?
3. If there is a problem in terms of Y+, What is your suggestion for solving this problem?
Y+ On the blade:
Y+ On the Hub
more explanation about hub position:
Thanks.
aja1345 is offline   Reply With Quote
Old   June 14, 2016, 00:09
You need to check the sensitivity to y+ for your case. Run a simulation with a coarser or finer y+ and see if it makes a difference to parameters you care about.
You can't tell if the y+ is OK from a contour plot.
aja1345 likes this.
Old   June 14, 2016, 00:19
Aja
Thanks,
Why?
I think that Y+ value have to be match with turbulence model.
For example, Y+ should be equal to about 1 in K-W SST.
Am I right? What is your idea?
I am grateful that guide me more in detail.
Old   June 14, 2016, 00:26
Aja
Is there difference between "grid sensitivity" and "grid independence"?
Could you please explain me the difference between the two terminologies, 'grid Independence' and 'grid Sensitivity '
Old   June 14, 2016, 03:03
Why?
Different simulations have different sensitivities to wall modelling. So some simulations are OK with very large y+, some require y+ to be closely controlled.
This is a very common misconception with SST. You do not need y+=1 for SST. Two reasons:
1) If the result is not sensitive to wall resolution
2) If the wall function approach works well then you want y+>11
You ONLY want y+=1 when you know you are sensitive to near wall resolution AND you know you need to integrate to the wall as the wall function approach will not work.
Grid sensitivity means that when you change your grid your results change. This is bad and means your simulation is going to be inaccurate.
Grid independence means that when you change your grid your results do not change. This is what you want and is a necessary requirement for validation of a simulation.
aja1345 likes this.
Old   June 14, 2016, 04:03
Aja
Thanks for your clear reply.
What is maximum of Y+ value here?
How do i find this maximum value?
Old   June 14, 2016, 06:12
It depends on your application - there is no universal answer. You have to do a sensitivity analysis.
aja1345 likes this.
Old   June 15, 2016, 10:39
Aja
Thanks.
Y+=11.225 is the transition to the log-law region.
Now I have one question:
We know that buffer layer is between 5 to 30. So it seems somehow wrong to place first layer in buffer layer!
Can you explain in this case?
Old   June 15, 2016, 19:58
In some cases that might be the case. But if your simulation is not sensitive to near wall boundary layer effects then you can stick the first cell where ever you like and it won't make any difference. So you need to determine for your case what level of sensitivity you have and act appropriately. There are no universal answers.
aja1345 likes this.
eddy dissipation model: combustion doesn't occur roukaia FLUENT 2 November 18, 2020 10:23
Turbulence model choice dave13 CFX 3 December 22, 2015 07:12
problem with solving lagrange reaction cloud Polli OpenFOAM Running, Solving & CFD 0 April 30, 2014 07:53
manualInjection model in sprayFoam Mentalo OpenFOAM Running, Solving & CFD 1 April 2, 2014 09:29
Problems bout CFD model of biomass gasification, Downdraft gasifier wanglong FLUENT 2 November 25, 2009 23:27
