April 20, 2017, 12:41 |
Effect of free surface on hydrofoil lift
Darlin L. V
Rep Power: 9 |
hi guys,
i'm doing a project on analysing the effect of the free surface on hydrofoil lift performing on an open channel using ANSYS CFX and i'm getting some odd results for the lift coefficient as i'm using the following equations for the drag and lift forces Lift=∫Pcosθ-∫Ʈsinθ since the lift is based on pressure and shear pressure around the airfoil. i'm supposed to get a Cl value up to 1.5 but i'm getting up to 3.4 |
April 20, 2017, 18:52 |
Rep Power: 143 |
Have you looked at the usual issues to establish accuracy: https://www.cfd-online.com/Wiki/Ansy..._inaccurate.3F
I have attempted this exact simulation several years ago, amazingly enough. I also found it a very difficult one to get accurate results on. This is because you have both flow over an airfoil (which probably has turbulence transition as a significant contributor) in addition to the effect of the free surface disrupting the pressure field. It is a challenging model. And by the way, just use the force() function to get forces. There is no need to integrate pressure and shear forces over a surface. Let CFX do that for you. |
free surface flow, hydrofoil lift, lift coefficent, lift force, open channel flow |
Display Modes | |
[Gmsh] Problem with Gmsh | nishant_hull | OpenFOAM Meshing & Mesh Conversion | 23 | August 5, 2015 02:09 |
[snappyHexMesh] Layers don't fully surround surface | EVBUCF | OpenFOAM Meshing & Mesh Conversion | 14 | August 20, 2012 04:31 |
Free surface VOF (fluid render effect) | franco | STAR-CD | 1 | July 20, 2009 05:42 |
CFX4.3 -build analysis form | Chie Min | CFX | 5 | July 12, 2001 23:19 |
Code with reliable free surface capability in a rotating system | Subhasish Roy Choudhury | Main CFD Forum | 1 | September 4, 1998 18:47 |
