export csv. file in each design point of a parametric solution
Hello everybody,
I'm doing a parametric simulation of a refrigeration pipe, refrigerated with water. I have to do 75 simulations by changing the geometry, the inlet heat flux and the inlet velocity of the water. I have defined all the design points by defining all the input parameters (Velocity inlet, inlet heat flux and the geometry variables imported from a solidworks file) and the output ones (Pressure drop (In-Out water), diference between Temperature in and out of the water and the average temperature of the inlet heat flux surface). The problem is that I also need to export of every design point an excel archive (.csv) with the temperatures of each node in the inlet heat flux surface, to let me calculate in excel the standard deviation of the temperature in the surface in every configuration. I know how to do it manually in CFX-post, just going to file->Export->Export.. and then defining the surface and the variable, but it can only be done for one case. So I need your help, to see if there is a way to export this data file (.csv with the temperature of every node in the heat flux inlet surface) in every design point of the parametric simulation. Maybe there is a command I don't know or maybe by scripting some commands in the command editor, I've never programmed in Perl language, I've been looking to some tutorials, but I didn't find a way to do it. Thank you for your Help, Vikun |
If you were looking for exporting "each time step" of a transient run then this would help
http://www.cfd-online.com/Forums/cfx...tml#post385850 but for parametric solutions I have no clue. Nevertheless maybe the perl script will help you find the right way to do it. At least it helped me to have a "template" and then iterate myself to the right solution by try and error :) |
Anyone has a better idea or has had the same problem as me?
You could calculate the standard deviation in cfxPOST
-> http://www.cfd-online.com/Forums/cfx...-cfx-post.html than set it as an output parameter it would save you hours of time. let almighty ansysCFX do the job for you why bother spending time with exel if it is unnecessary. |
Thank you so much for your help Vikun |
Well Mr. Glenn stated in the link:
The CEL expression is count(). AND areaaverage() can be used to get average on that surface I hawent looked at this topic deeply enough yet. This is just a thought and it should work beautifully. Thanks goes to BalanceChen and ghorrocks. |
Hello Everybody again,
I've created an script that exports the csv file that I want, the problem is that I don't know how can I do to save it in CFX-post, to let the program execute that script automatically in every simulation. If I open the cfx-post and I paste the code in the command editor and click to process, it creates the csv file. So, there is a way to make the program execute that code in every simulation of the 75 parametrics simulations I've prepared? (in order to export the 75 csv files) Thank you so much, Vikun |
Don't know how to automate the process, but when you save your script as a .cse file you can "play" it directly by clicking on "Session->Play Session" in CFX Post.
No need to paste it every time to the command editor |
