Near Wall Or Wall Adjacent Temperature Required |
July 16, 2016, 10:07 |
Wall Temperature Expression In CFD-Post Showing No Value
Dear all,
Hi. Hope all are well. I am trying to make the expression "MyHTC = Wall Heat Flux / (Wall Temperature - MyBulkTemperature)" as guided in the FAQs. For this the required "Wall Temperature = (Wall Heat Flux / Wall Heat Transfer Coefficient) + Wall Adjacent Temperature". I made the following expression in CFD-Post for Wall Temperature i.e. "(Qwall/htc)+tnw" but I am getting no values but <variable> [K]. Why is that? Also where do I get "MyBulkTemperature"? Any help would be appreciated. Can somebody please help? Would be grateful. Thank you. Last edited by Shomaz ul Haq; July 16, 2016 at 12:42. |
July 16, 2016, 11:18 |
July 16, 2016, 11:47 |
urosgrivc
Rep Power: 11 |
Do you want your HTC walues to be based on the farfield temperatures?
if so You can set an expert parameter T-bulk in (pre) and it will calculate walues based not on near wall (bulk) temperature but from your fixed (T-bulk) value. If you dont set the (T-bulk) value, temperatures near wall are -> average temperatures in the first element near wall, and are very grid dependant. smaler the element higher the htc, to some extent of corse and not for all cases. |
July 16, 2016, 12:31 |
Thanks urosgrivic. Yes one can use the expert parameter "Tbulk for HTC", but I am using the second approach. I am trying to create my own own expression for "MyHTC". So I need help regarding my CFD-Post expression for Wall Temperature i.e. "(Qwall/htc)+tnw" but I am getting no values but <variable> [K]. Would be grateful for help. Thank you.
July 17, 2016, 05:59 |
Would be grateful for any help. Thank you.
July 17, 2016, 06:42 |
Rep Power: 143 |
What are you trying to do? I think you are asking how you get the HTC based on a defined bulk temperature from a simulation you have already completed, so you want to do it in post processing.
If this is the case, isn't the equation you want MyHTC = Wall Heat Flux / (Wall Temperature - MyBulkTemperature)? Then Wall Heat Flux and Wall Temperature are solution variables and MyBulkTemperature is a value you define. Now MyHTC is defined and the function should work. |
July 17, 2016, 07:13 |
Thanks a lot Glenn. Yes I am doing all this in CFD-Post. I need help regarding my CFD-Post expression for Wall Temperature i.e. "(Qwall/htc)+tnw". This is the expression I used but I am getting no values but <variable> [K]. Also what value or expression of "MyBulkTemperature" should I use and how? Would be grateful. Thank you.
July 17, 2016, 07:28 |
Rep Power: 143 |
Can you get wall temperature directly with "Wall Temperature" or "Twall"?
July 18, 2016, 13:14 |
#9 |
Erik
Rep Power: 23 |
You get no value for your expression because it is dependent on position. You can make a variable, and then plot it on a surface. Or draw a line along the wall, and make a chart for it on that line.
For MyBulkTemperature, you would use whatever temperature or expression you want which defines the bulk temperature of the fluid. For example, in a pipe, I use the mass flow average of the temperature in each cross section along the pipe. so it is a function which changes along the length of the pipe. Your case for MyBulkTemperature may be different. |
Display Modes | |
Fixed Wall Temperature Pipe With Odd Results | khoopes | CFX | 5 | June 15, 2015 07:58 |
Is wall ajacent temperature equal to conservative temperature of the wall? | shenying0710 | CFX | 8 | January 4, 2013 04:03 |
Question about bcdefw.f for wall temperature bc. | Jimmy | Siemens | 10 | March 18, 2008 15:28 |
How to input the wall temperature b.c.? | Jimmy | Siemens | 9 | March 14, 2008 09:31 |
Multicomponent fluid | Andrea | CFX | 2 | October 11, 2004 05:12 |
