July 18, 2016, 10:01 |
Force and torque evaluation
Jiri
in CFD POST, I cant evaluate torque and force on a few faces, I receive error: ERROR: Flow data - vertex count mismatch other evaluation works on these faces, such as area average pressure, temperature etc. ?????????? |
July 18, 2016, 20:35 |
Rep Power: 143 |
I have never seen that error before. There must be something very strange about the face you are doing this to.
July 21, 2016, 04:16 |
Jiri
Yes it is very strange. I tried to evaluate Area Integral of Pressure on given surface in X direction as well as Wall shear and it works! Obviously I would be able to evaluate the forces on the basis of these surface integrals.
But I need to evaluate torque as well. However to create my own expression to evaluate torque to an axis of my local coordinate system seems to be a difficult task. |
June 29, 2017, 05:14 |
Rep Power: 8 |
can anyone help me? I have the same error. Thanks |
July 28, 2017, 06:36 |
Hi, I also met the same problem. very strange. I used local parallel in CFX when solving my problem. The results are then evaluated in CFDPost. I used the exactly same .def file with several different partition number, then I met the problem for some of them. Have no idea about this.
September 4, 2019, 10:29 |
Csaba Hetyei
Rep Power: 6 |
I have the same issue. I tried with simplified simulation and it's works (2D cases and rotating a "brick"), the CFX/CFD-Post can make the a chart for this simple cases... So I have still the CFD-Post error (ERROR Flow data - vertex count mismatch.) for my real case, but I can have my results. I made a monitor for my tourqe expressions and from the solver I export my results. (see the attached image)
Csabi |
How to monitor torque or force in CFX? | aja1345 | CFX | 11 | April 15, 2016 03:58 |
Forces & Torque in CFX-Post | Typhoon | CFX | 1 | September 13, 2013 07:40 |
Force / Torque on car body | Chonker | CFX | 0 | November 30, 2010 08:09 |
Torque coefficient evaluation | Agni | CFX | 0 | October 3, 2008 04:43 |
positive and negative torque forces | Wei-Haur Lam | CFX | 0 | March 19, 2008 07:45 |
