Normalised Imbalance Summary for a transient simulation |
July 27, 2016, 03:33 |
Thomas B
Rep Power: 10 |
at the end of a transient simulation, a .out file is generated. The normalised imbalance summary for mass, momentum, H-Energy is indicated in the file. But in a transient simulation, the imbalance can be calculated for each time step, so I wanted to know about the values for the normalised imbalance summaries in the .out file:
July 27, 2016, 09:16 |
Rep Power: 32 |
You can monitor the equation imbalances in the ANSYS CFX Solver Manager.
Create a New Plot, Select IMBALANCE, Select equation of interest, Press Apply.. If you really want to see the summary at every timestep, check the expert parameters panel in ANSYS CFX-Pre and look for "monitor balances" or similar. Hope the above helps, |
July 27, 2016, 13:46 |
Thomas B
Rep Power: 10 |
Hello Opaque,
thanks for your answer. I already monitor the H-Energy Imbalance (the only physical quantity with which I have significant imbalances so far). For most of the simulation time, it remains between -1% and 1%, and usually gets totally crazy (between -30% and 30%) at the end of the simulation. I know I can control this with adaptive time stepping but the simulation time is then multiplied by approximately 15. So, with what you said, I deduce that the normalised imbalances that are given in the .out file are actually the imbalances of the last time step. So I will have no choice but to apply a conservation target of 0.01 and wait 10/11 days till the simulation finishes (because with this condition, the time step won't go over 1,1e-7s, and the duration of my simulation is a couple ms). |
Transient RANS Simulation | Bazinga | Main CFD Forum | 5 | June 21, 2017 11:21 |
Question on transient simulation in OpenFOAM and FLUENT | nicklj | OpenFOAM Running, Solving & CFD | 4 | May 8, 2014 22:30 |
Exporting data of transient simulation DURING a simulation, at user locations ? | Milan2013 | CFX | 0 | April 18, 2014 03:47 |
Imbalance in transient simulation | Roland R | CFX | 3 | December 9, 2009 05:39 |
how to identify transient simulation converged | littlelz | CFX | 5 | January 27, 2009 18:13 |
