Cannot achieve negative wall shear stress values in CFD Post (ANSYS)
Old   August 2, 2016, 11:52
Default Cannot achieve negative wall shear stress values in CFD Post (ANSYS)
Sam
SAtkins is on a distinguished road
Hello all,
For reference, I'm using ANSYS 17.1 CFX
I am working with a simulation that models 1/6 the geometry of a circular disk (so it basically looks like a slice of pizza). I input a rotational sine wave on the fluid above the disk, which should cause a shear stress equivalent sine wave with an amplitude of +/- 2 Pa. (Labeled Target on graph)
In CFD Post, I am extracting the radial component of the shear stress with the transform Radial Wall Shear Stress = -(0.5 Wall Shear Stress X + 0.866 Wall Shear Stress Y) (from a trig transform).
When the sine wave should be changing direction and going negative down to -2 Pa, instead, the waveform achieves a minimum value of ~ -0.4 Pa (Waveform Labeled "0" on graph). I have tried to over-exaggerate the input angular velocity of the negative portion of the sine wave, and when I do this, I get a curve full of positive "humps" (think the first half period of a sine wave, repeating over and over at the applied amplitude). (Waveform Labeled "1" on graph)
Do you think this could be a problem because I'm modeling 1/6 of the geometry as a symmetry plane? Or is there some problem with my post processing?
TL;DR = Cannot achieve negative wall shear stress values in simulation with a sine wave input (and I'm not exporting the absolute value or magnitudes of shear stress, either).
Any help is much appreciated!
SAtkins is offline   Reply With Quote
Old   August 2, 2016, 20:39
The variable "Wall Shear Stress" is the magnitude of the vector so is always positive. But "Wall Shear Stress X/Y/Z" are the components and should be able to go negative when they need to. So I do not know why you are seeing what you are seeing.
Your result also looks wobbly so I am suspicious there is general accuracy problems as well. Have a look at the FAQ: http://www.cfd-online.com/Wiki/Ansys..._inaccurate.3F
Old   August 3, 2016, 08:14
Sam
Right, I am extracting just the Wall Shear X and Wall Shear Y components now - my Wall Shear X goes negative in the appropriate places while my Wall Shear Y is very positive (2 times the magnitude of X). My equation for radial shear stress should take care of the positive values, though, as it adds -0.866 Wall Shear Y.
I've looked at that link - my solutions are definitely converging. I've ran a mesh analysis and don't see any differences in output when changing the grid size. At this point I'm pretty stuck
Old   August 3, 2016, 14:27
Sam
Update:
I have figured out the problem - and it's my bad trig. Instead of using the formulas I did to pull out what I called radial, which is really circumferential, shear stress - I just needed to use simple trigonometry.
Circ = cos(30)WSSx - sin(30)WSSy
Circ 1 = cos(3)WSSx + sin(30)WSSy
Circ produced a waveform that was inverted from my target. Circ 1 seemed to produce the output I was looking for (minus, minor inertial effects not taken into the WSS to AV transform I used - which is expected).
Anyways, I wanted to update with the hope that anyone having this problem in the future might get some help on transforming x and y WSS components into a circumferential shear stress component tangential to the direction of a rotational flow.
cfd post, wall shear stress
Natural convection in a closed domain STILL NEEDING help! Yr0gErG FLUENT 4 December 2, 2019 00:04
Calculation of Wall Shear Stress Dave442 CFX 36 July 12, 2016 04:12
Wall shear stress in channel flow sreeyuth OpenFOAM Running, Solving & CFD 2 September 5, 2014 10:02
How to get a value of wall shear stress for UDF shileijerry Fluent UDF and Scheme Programming 0 June 18, 2013 10:50
WALL SHEAR STRESS Min-Hua Wang CFX 0 April 3, 2002 17:40
