Single v.s. double precision
Like Tree8Likes
  • 1 Post By Confused
  • 1 Post By deLuther
  • 5 Post By Glenn Horrocks
  • 1 Post By Glenn Horrocks
Old   April 7, 2004, 03:05
Default Single v.s. double precision
Confused
I have seen it so many times now, when I compare the solution in single and double precision there is a huge difference. Wonder why I still bother to calculate in single
I believe that my mesh is fine enough, I have used 750000 pure Hexahedral cells for a small geometry. I use high resolution for the advection scheme. The convergence rate and level is similar for the single and double precision calculation. Solver CFX5.5
But why does this happens, Is it always like that?
Vinay94 likes this.
Old   April 7, 2004, 05:06
Default Re: Single v.s. double precision
deLuther
I also noticed that double precision is better even for relatively simple case. Because single precision can give wrong results...
Vinay94 likes this.
Old   April 7, 2004, 19:13
Double precision will be significant if tiny relative differences are significant. Examples where you would expect double precision to make a difference are natural convection (especially if modelled with the fully compressible option); meshes with a large difference between the largest and smallest element sizes; large geometries with small but significant features; flows with large pressure/velocity/temperature variations etc etc.
Double precision is always more accurate, but does run slower (on 32 bit machines at least) and takes up more memory.
Glenn
Old   April 8, 2004, 06:48
Rui
Is it possible to estimate how slower a double precision simulation is, compared to a single precision one?
Thanks,
Rui
Old   April 12, 2004, 18:42
Hi Rui,
I think from memory my last comparison (on a Intel Xeon/WinXP machine) double precision took 30%-50% longer than single precision. This assumes that the simulation converges OK with both single and double precision.
regards, Glenn
Vinay94 likes this.
Old   April 16, 2004, 23:49
Neale
Are you sure you are not running in absolute pressure mode. i.e. you set the reference pressure to zero and set all your boundary conditions in absolute pressure?
If the pressure variation in your problem is not huge then you should use a pressure that represents the average pressure.
Neale
Old   April 18, 2004, 06:23
Atit
My problem is about natural convection. I use the adaptive mesh also. The maximum iterations in each adaption step is 200. When each adaption step end, I got the message: ---------------------------------- WARNING: The following data is being reduced from double
precision to single precision on interpolation.
What = G/BETA/ENERGY
Where = ZN1/VX
When = 200
What = G/CONDUCT_FL1
Where = ZN1/VX
When = 200
What = G/CVVOL
Where = ZN1/VX
When = 200
What = G/DENSITY_FL1
Where = ZN1/VX
When = 200
What = G/DRHODP_T_FL1
Where = ZN1/VX
When = 200
What = G/ENTHSTAT_FL1
Where = ZN1/VX
When = 200
What = G/ENTROPY_FL1
Where = ZN1/VX
When = 200
What = G/MACH_FL1
Where = ZN1/VX
When = 200
What = G/PRES
Where = ZN1/VX
When = 200
What = G/PTOT
Where = ZN1/VX
When = 200
What = G/SPHEATP_FL1
Where = ZN1/VX
When = 200
What = G/SSTRNR_FL1
Where = ZN1/VX
When = 200
What = G/TEMP_FL1
Where = ZN1/VX
When = 200
What = G/TTOT_FL1
Where = ZN1/VX
When = 200
What = G/VEL_FL1
Where = ZN1/VX
When = 200
What = G/VISCDYN_FL1
Where = ZN1/VX
When = 200 ------------------------------------------ What does it mean? and what is "FL1"?
Old   April 18, 2004, 18:21
Hi Atit,
From another post I understand you are using 10 refinement levels in your mesh adaption. I suspect single precision will not be accurate enough to capture the very fine meshes this could create. It might even be so fine double precision can't capture it.
As I said in my previous post, 10 refinement levels is too much. Reduce it to between 3 and 5.
Glenn
Old   April 19, 2004, 05:30
Atit
Dear Mr.Horrocks, Thank you for your answer. Yes now I reduce to 5 steps as you recommend. However I am sorry, but I do not understand your suggestion on SP and DP. Does you mean I should use double precision? Furthermore, do you know why CFX change the calculation from DP to SP in some region? Thank you very much.
Atit
Old   April 19, 2004, 18:33
Hi Atit,
My comments regarding SP and DP relate to the fact that with 10 refinement levels you will get some extremely small elements in relation to the rest of the grid. I suspect that a SP number will not have enough resolution to resolve these small elements accurately, leading to problems with accurate predictions of the fluxes etc etc, ultimately leading to unstable solver behaviour and probable divergence.
I have no idea why CFX hanged to SP in some regions. I have not experienced it in any of my work.
Glenn
Old   August 26, 2016, 07:19
urosgrivc
urosgrivc is on a distinguished road
Hi
Does somebody know how to set double precision as a DEFAULT for cfx?
When solving sistems with RSM there is only option for number of threads and not for SP or DP?
Execution control in cfx pre is acting kinda strange, if I set Execution controls in cfxpre (no. of cores, DP...) the solver fails.
Thank you
urosgrivc is offline   Reply With Quote
Old   August 26, 2016, 08:34
This is a 12 year old thread. The fact that I posted on this thread way back then explains why I have creaky bones now.
I don't think you can set double precision as a default. You will just have to make a habit of clicking the double precision tick when you set up a new simulation.
I do not understand your RSM comment. The choice of double or single precision has nothing to do with what physics you have selected - at least to my knowledge.
I do not understand your comment on execution control in CFX-Pre. It works fine for me. But it is easily set in solver manager or command line, so it is not a big hassle to work-around.
ghorrocks is online now   Reply With Quote
Old   August 26, 2016, 14:03
urosgrivc
Thank you,
I ment Remote Solve Manager; if I use it, there is no other way to solve it in Double Precision than to set an execuiton control in pre as there is no settings for sp or dp.
Old   August 27, 2016, 06:39
OK, I will take your word for it. I do not use remote solve manager so cannot help you there.
Old   November 10, 2016, 04:36
Default how to enable double precision in fluent.
  #15
abhijeet jaiswal
abhijeet is on a distinguished road
Originally Posted by Glenn Horrocks
;68698
Glenn
dear sir,
myself abhijeet jaiswal and i am working on the simulation of jet blast defelector with density based model,high Re,and also temperature neara about 650K and i have same error problem as you discuss above so sir can you explain me how to change to double precision from single precision to solve this problem to get better result...
abhijeet is offline   Reply With Quote
Old   November 10, 2016, 04:42
urosgrivc
There are 2 comon ways of seting double precision:
1- in cfx-solver manager
2- in execution control in CFXpre
Continuing User Defined Real Gas Model issues aeroman FLUENT 6 April 8, 2016 03:34
Parallel User Defined Real Gas Model aeroman FLUENT 4 July 1, 2015 06:09
Missing math.h header Travis FLUENT 4 January 15, 2009 11:48
what's wrong about my code for 2d burgers equation morxio Main CFD Forum 3 April 27, 2007 10:38
REAL GAS UDF brian FLUENT 6 September 11, 2006 08:23
