turbo problem
Like Tree1Likes
  • 1 Post By CycLone
Old   October 28, 2008, 08:52
Default turbo problem
Toralf
hi, after simulation of a turboproblem I would like start the turbotool in cfx-post. after intialization it comes following message: "WARNING failed to initialize component 'component 1' in domain 'rotor' for conversion type 'cartesian to turbo'. I have defindes every part and domain. who can give an advice? thanks.
Old   October 28, 2008, 09:08
Default Re: turbo problem
CycLone
Turbo initialization only works for bladed or axisymmetric components, i.e. those that circumferential swept hub, shroud, inlet and outlet locations. If component 1, in your case, is a non turbo component (i.e. an inlet scroll upstream or a volute downstream), it cannot be initialized. Just uncheck the box next to it and Post won't try initializing it.
If it is a turbo component, make sure the hub, shroud, blade, etc. regions are located properly. Post has a pre-defined list of region names it uses to identify these, but you can manually locate them as well.
-CycLone
jiaji lu likes this.
Old   October 29, 2008, 13:15
sam
Are you using meshes created in turbogrid?
Old   April 15, 2010, 20:17
blackbody is on a distinguished road
i'm having the same probelem!!!
I want to analyse a 1.5 stage axial turbine (which I created with TurboGrid) in the CFD-Post Turbo Mode.
When I want to "Initialize All Components" I get the same error as written above...
I think I set everything correctly:
I created a Stator1 mesh, a Rotor1 mesh and a Stator2 mesh (one blade each).
Than in CFX i used the Turbomachinery tool to set up the whole arrangement.
To get a 2:3:2 ratio for Stator1/Rotor1/Stator2 i applied following:
"Passaged and Alignment" -> "Passages to Model" -> 2, 3, 2 respectively.
Why is that error and what can I do since I really have to use this Turbo Mode in CFD-Post.
Thank you guys very much for your help in advance.
blackbody is offline   Reply With Quote
Old   August 16, 2016, 04:34
Brett
Bdew8556 is on a distinguished road
Im having a similar issue.
Im trying to generate compressor speed lines, so im setting input and output parameters and varying the mass flow with constant rpm to find output pressure.
Again an issue with initialization.
Did anyone figure this out?
Bdew8556 is offline   Reply With Quote
Old   September 10, 2016, 15:07
spl
spl
spl is on a distinguished road
Have you tried using the manual initialization? If you have named the necessary mesh regions you should be able to select the various parts and it should work fine.
spl is offline   Reply With Quote
UDF compiling problem Wouter Fluent UDF and Scheme Programming 6 June 6, 2012 05:43
Problem Importing Geometry ProE to CFX fatb0y CFX 3 January 14, 2012 20:42
natural convection problem for a CHT problem Se-Hee CFX 2 June 10, 2007 07:29
Adiabatic and Rotating wall (Convection problem) ParodDav CFX 5 April 29, 2007 20:13
Is this problem well posed? Thomas P. Abraham Main CFD Forum 5 September 8, 1999 15:52
