October 18, 2016, 02:04 |
Rep Power: 143 |
What are you trying to model? What are you trying to learn from this simulation?
Do the solid particles move? Are you interested in the air flow around this rotating thing? What are the solid particles - size, shape, density, other relevant properties (eg sticky, slippery, hot, cold etc) |
October 18, 2016, 02:59 |
#3 | |
I don t know how set that mesh/BC of place/volume of particles will on the disk. Parametrs of solid prcl don t interesting (no termal, no deforming) |
October 18, 2016, 05:04 |
Rep Power: 143 |
I do not understand your reply. Are the particles stationary or do they have trajectories? Are you trying to model the motion of the particles or the air around it?
October 18, 2016, 05:23 |
I'm trying to simulate the trajectory of the solid particles that are on the rotating disk. Around the disc - the air.
October 18, 2016, 05:40 |
Rep Power: 143 |
What forces act on the particles?
October 18, 2016, 06:00 |
Rep Power: 143 |
Does it have particle to particle forces? Or particle to rotating disc forces?
October 18, 2016, 06:05 |
#9 |
October 18, 2016, 06:12 |
#10 |
Rep Power: 143 |
In your first drawing you show a pile of particles. To get a pile there needs to be particle to particle forces. Can you confirm whether there are particle to particle forces?
Also - in a simple case the particles will just fly off the disk in straight lines. This does not sound like a case worth bothering to do a CFD simulation. What is happening to make it complex enough to do it by CFD? |
October 18, 2016, 07:15 |
#11 | |
I think that I must simulate dynamic of paticles in CFD. and add gravity |
October 18, 2016, 07:18 |
#12 |
Rep Power: 143 |
CFX cannot do particle to particle collision forces in a Lagrangian model. I suspect you need a Langrangian model for this. This means CFX is not a suitable simulation software for your application.
October 18, 2016, 07:40 |
#13 |
October 18, 2016, 17:36 |
#14 |
Rep Power: 143 |
I understand Fluent has a very simple particle to particle collision model. You would have to check it out.
For full particle to particle collision modelling you would need to look at discrete element modelling (DEM) like EDEM or ROCKY. These softwares can be coupled to CFD software so the CFD software models the fluid flow and the DEM software models the particle collisions. |
dsmcFoam setup | hherbol | OpenFOAM Pre-Processing | 1 | November 19, 2021 01:52 |
Difficulty in calculating angular velocity of Savonius turbine simulation | alfaruk | CFX | 14 | March 17, 2017 06:08 |
How to simulate fluid flow with solid particles mixed with them?? | pankajbhatter9 | FLUENT | 2 | November 2, 2013 12:55 |
Terrible Mistake In Fluid Dynamics History | Abhi | Main CFD Forum | 12 | July 8, 2002 09:11 |
Particles in slow dense fluid | newbie | Main CFD Forum | 6 | December 6, 2001 09:43 |
