[Sponsors] | |||||
Hey,
I'm doing a two phase flow (water-air) in a mixing vessel. Everything runs fine, but I have a problem with an important monitoring point. I need the data for Volume fraction of air or the Volume of air in the water. I have the VF data for the rotating domain and for the whole vessel, but i have no idea how to monitor this for the whole region under the surface of water (under the black line), because as you can see the geometry of this surface is so that i can't do a subdomain, which will fit to this criterion. ![]() Had any one the same problem and knows how to deal with this? "About the simulation:" It's a transient simulation of a mixing vessel for the dispersion of air in water. The stirrer has a speed of 1000rpm and the air inlet is 12l/min. Euler-Euler with ishii-zuber drag model. |
Rep Power: 146 ![]() ![]() ![]() ![]() |
In CFD-Post you can define the liquid region (ie under your black line) as a volume defined by an isosurface. Then you can get the volume fraction of air inside that volume.
I did the isosurface in cfx-post but it makes not only the surface from water on the top (black line) of the vessel, but also on all the other borders between air and water (where the bubbles are) so I don't truly understand how would you realize that idea of yours?
And the next thing is, I don't write every time step, I only do every 2000th of it. Because I only need a few parameters from monitoring and the output file would be to large. Also in cfx-post I can only get variables for the written time steps, or? If yes, than I get only 6 data in 1s simulation. |
You have to make a volume from the isosurface. The isosurface is just a surface so you cannot do volume integrals on it.
Have a look in the output options to write either a reduced set of output variables for a large number of time steps, or even to do some basic post processing as the solver progresses. |
I will try. Thank you for now
| Thread Tools | Search this Thread |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| Monitoring a point in dynamic mesh | Modisa | FLUENT | 1 | December 19, 2008 04:04 |
| monitoring fluctuations at a point | ED | FLUENT | 2 | February 24, 2007 05:05 |
| monitoring fluctuations at a point | ED | Main CFD Forum | 0 | February 23, 2007 12:58 |
| How can I create a rotating monitoring point? | Andy Cong | FLUENT | 0 | September 10, 2006 21:09 |
| CFX4.3 -build analysis form | Chie Min | CFX | 5 | July 13, 2001 00:19 |
