June 23, 2011, 10:32 |
mixing cup temperature
George Theo
Rep Power: 15 |
I want to calculate the mixing cup temperature - Tm=(1/umean*A)*<integral>(uT dA) - at a cross section (plane) of a rectangular duct. I have the velocity and temperature profile on the plane. Any suggestions on how to calculate the integral on the plane? |
June 23, 2011, 10:33 |
George Theo
Rep Power: 15 |
I meant the velocity and temperature FIELD.
June 23, 2011, 18:59 |
Rep Power: 143 |
This is easy. In CFD-Post create a user variable which is u*T. Then use the function calculator to get the area integral of this user variable over the area you define.
June 24, 2011, 16:21 |
Joseph Tipton
Rep Power: 15 |
I believe you can also use massFlowAve(Temperature)@<plane name> to achieve the same calculation.
October 26, 2016, 17:02 |
custom field function i
Xiaobing Zhang
Rep Power: 11 |
build a custom field function in define. input u*T on the panel. get the integral then do the operations you want.
Calculation of the Governing Equations | Mihail | CFX | 7 | September 7, 2014 06:27 |
cup mixing temperature | debuchak | FLUENT | 0 | June 22, 2009 14:21 |
mixing cup temperature using posdat.f | Thiyagarajan | Siemens | 1 | November 28, 2007 00:00 |
Mixing Cup...F77 Code | Robin K | Main CFD Forum | 0 | July 9, 2005 17:39 |
mixing cup temperature using posdat.f | Boban | Siemens | 0 | July 8, 2005 10:46 |
