what is the right pitch change option?
Old   November 2, 2016, 14:07
Default what is the right pitch change option?
Alex
Red Ember is on a distinguished road
Hi to all!
Can anybody give me advice what is correct choice for rotor-stator interface if rotor blades number is twice more than stator vanes one? I suppose the stage model is the right choice, but is there any differences between automatic, value and specified pitch angles options? May be any snake in the grass?
P.S. About task: 7-staged axial compressor, turbogrid mesh, steady-state case.
Using stage/automatic angles options, the only robust solution was yielded by massflow&temperature at inlet and static pressure at outlet combination, although the result is invalid - high pressure values (about *1.5) and low efficiency (about /1.5)...
Red Ember is offline   Reply With Quote
Old   November 14, 2016, 02:45
Alex
Specified pitch angles option leads to solver fail every time. Only automatic one works relatively well, I don't know why.
BC combination p*in - p out leads to solver fail, hence I have to use Gin - p out.
If I find out something else, I jot down a comment.
Simple piston movement in cylinder- fluid models arun1994 CFX 4 July 8, 2016 02:54
Ansys CFX problem: unexpected very high temperatures in premix laminar combustion faizan_habib7 CFX 4 February 1, 2016 17:00
Difficulty In Setting Boundary Conditions Moinul Haque CFX 4 November 25, 2014 17:30
Setting rotating frame of referece. RPFigueiredo CFX 3 October 28, 2014 04:59
Low Mixing time Problem Mavier CFX 5 April 29, 2013 00:00
